Author Topic: Fuel tap o-ring  (Read 575 times)
Offline casperdog
Fuel tap o-ring
« on: June 15, 2019, 04:26:44 PM »
Hi, does anyone know the size of the o-ring that seals the lever on this type of tap... or a link to an eBay item?
Many thanks
Re: Fuel tap o-ring
« Reply #1 on: June 15, 2019, 06:15:38 PM »
If you mean on the lever dont think its an O ring and its a flat version tap to tank from memory only available in a strainer kit for many pounds.
Offline casperdog
Re: Fuel tap o-ring
« Reply #2 on: June 15, 2019, 09:56:58 PM »
Definitely an o-ring...on this one at least😊 sits on the back of the lever behind the front plate..will take it apart again and measure. It's seeping fuel from the front of the tap.
Offline casperdog
Re: Fuel tap o-ring
« Reply #3 on: June 17, 2019, 07:37:34 PM »
O-ring in question....diameter on lever is 19.0mm and bore it sits in is 22.25mm. Going to order 19mm ID,  2mm section.
Offline ka-ja
  • ken
  • yoshi 460
Re: Fuel tap o-ring
« Reply #4 on: June 17, 2019, 08:05:23 PM »
My tap has a corregated washer type spring not an o ring, I would check further if I was you, previous owner repair?
nice bike,nothing in the bank
Offline Moorey
Re: Fuel tap o-ring
« Reply #5 on: June 17, 2019, 08:25:47 PM »
It's the same type of tap as mine on the F model and should have a o ring.
Offline casperdog
Re: Fuel tap o-ring
« Reply #6 on: June 17, 2019, 08:49:58 PM »
Just had a look at the drawing for the K5 (should have mentioned the model) and matches what I've got. Shows the o-ring behind the tap lever.
