Author Topic: Intro  (Read 1924 times)
Offline Trygve
Intro
« on: December 02, 2008, 03:48:08 AM »
My name is Trygve Klem, and I live outside Lismore, NSW, Australia. I have recently bought a CB 750 SS 1978 model. Which I have started to sort out the various areas needing some attention. When I opened the dynamo cover where the stator is, some oil leaked out. Is there supposed to be oil in there. (as you can guess, it's a long time since I have owned a motorbike.
Re: Intro
« Reply #1 on: December 02, 2008, 07:10:58 AM »
Hello from all in the UK.
I don't think that a little bit of oil under the alternator cover is bad or uncommon.
You will probably meet more Aussies on or sister (global) site: www.sohc4.net - if you haven't found it already, it looks the same as this (uses the same software). Use the same username so that we all recognise you!
2022 Tiger Sport 660
Offline Trygve
Re: Intro
« Reply #2 on: December 05, 2008, 12:47:04 AM »
Thanks for the info. I have had the stator checked and it needs rewiring
Re: Intro
« Reply #3 on: December 19, 2008, 09:55:56 AM »
Thats very unusual as they are extremely robust and normaly only get damaged by accidents
