Author Topic: 550K1 - carb rebuild set  (Read 1053 times)
Offline Erny
  • CB750K7 CB550K1
« on: June 20, 2019, 01:36:36 PM »
As I still have issues with my stock carb 022A (550K1 1975, USA model), I'm preparing for eventual rebuild
Can you please recommend proven source of carb parts (kit)?
I found one on 4into1 https://4into1.com/carburetor-repair-kits-complete-set-honda-cb550k-1974-1976/ - but not sure about quality
They claim kit comes from Taiwan
Ideally if I can buy it in EU due to taxes/shipping...
I want to buy at least needle valves, needles with clips and emulsifier tubes, viton rings
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline Raymond_Y
Re: 550K1 - carb rebuild set
« Reply #1 on: June 20, 2019, 09:13:39 PM »
If you just want the o rings to rebuild the carbs you can buy them individually on eBay from specialist suppliers such as sealsuppliesuk at a fraction of the cost of the specialist kits.  I got enough for 6 sets of carbs for £20.  You also have the option to upgrade to Vito seal if you prefer.
Raymond
Raymond
1971 CB500K0 (being rebuilt)
1977 CB550K3 (bases for future 650 cafe racer)
Q plate CB550 in bits
« Reply #2 on: June 20, 2019, 09:56:38 PM »
Order a carb kit from Cruzin and replace the o rings with Viton from Gerben in Holland. If you use nitrile o rings, they swell up on contact with modern fuel   ;) ;)
Offline paulbaker1954
« Reply #3 on: June 20, 2019, 11:03:24 PM »
Absolutely 2nd Graham’s sound advice!!!
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Erny
  • CB750K7 CB550K1
« Reply #4 on: June 21, 2019, 11:26:22 AM »
Thanks guys!
So, with regards to viton O-rings, I need to know sizes and qty used...
I've seen it some time ago on the forum (here or us) but cannot find it now..
I need this for CB550K1 (carbs 022A) and also for my CB750K7 (PD41A carbs)
Thanks!
Offline Moorey
« Reply #5 on: June 21, 2019, 11:33:45 AM »
I was looking for the list of o rings sizes the other day and couldn’t find it either. Anyone know where it’s gone. I can’t remember if it was on here or the USA site.
Offline Seabeowner
« Reply #6 on: June 21, 2019, 01:15:37 PM »
For 022A & 627B carbs I used.
Float valve      5mm x 1.5
Main jet      3.5mm x 1.2
Float bowl      68mm x 2.0  But found it a bit big on dia.
Fuel tee      7mm x 2.0
Drain screw  5.5mm x 1.5
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Raymond_Y
« Reply #7 on: June 21, 2019, 01:26:19 PM »
Raymond
Offline Raymond_Y
« Reply #8 on: June 21, 2019, 01:32:54 PM »
The sizes are also in the parts list, which lists the float bowl size as 67 x 1.9 and the fuel T as 7.8 x 1.9.
Raymond
Raymond
