Author Topic: Gear Box Outer Cover  (Read 694 times)
Offline bucksfizz
  • 1973 CB750 Four K3
« on: July 04, 2019, 03:06:24 PM »
I'm trying to track down why I'm getting 0 volts at the oil pressure warning light.
I suspect that the oil pressure switch has failed.
My limited knowledge of these bikes tells me that the switch is located at the back of the crankcase on the left side.
As such, I'm trying to remove the outer gear box cover, but it goes only so far:
I can get my finger tips in between the cover and the crankcase, but the wretched cover won't budge any further.
How do I remove this cover without resorting to brute force and ignorance?
BTW, a fair amount of oil came out, which I wasn't expecting.
Re: Gear Box Outer Cover
« Reply #1 on: July 04, 2019, 03:12:32 PM »
The oil pressure switch is under this rubber cover, which is on the right of the engine.
« Last Edit: July 04, 2019, 03:19:17 PM by Nurse Julie »
Offline bucksfizz
« Reply #2 on: July 04, 2019, 03:22:48 PM »
Doh!
Thanks for the info - I'll just button up the gear box outer cover.
(If there were a red-faced icon, I'd use it.)
« Reply #3 on: July 04, 2019, 03:24:23 PM »
Don't forget to check your oil level when you have buttoned it all up 👍👍👍👍
« Reply #4 on: July 04, 2019, 03:49:04 PM »
Should get 12v between black wire at bulb and ground, the wire to switch grounds the bulb to make it lite up
Offline bucksfizz
« Reply #5 on: July 06, 2019, 04:13:32 PM »
New oil pressure switch arrived today, fitted it, and... oil light now comes on - hurrah.
Now let's hope it goes out again when I fire her up.
I'll add some more oil to the tank at the same time, Julie - not too bad running low oil on a dry-sumper, though.
« Reply #6 on: July 06, 2019, 08:27:21 PM »
I don't like anything running low on oil, wet sump or dry sump.....its unnatural 😁😁😁
« Reply #7 on: July 06, 2019, 09:21:17 PM »
When you tighten up the mission cover, make sure that you have not trapped any wire that run in the channel at the back of that cover.
Strange to see a early head on a K3  ;) ;)
Offline bucksfizz
« Reply #8 on: July 06, 2019, 10:08:32 PM »
What's a "mission cover"? (My ignorance of these machines is shining through.)
How can you tell it's an early head?
If it is an early head, it's probably not too surprising, given the bike's 46 year age.
« Reply #9 on: July 06, 2019, 10:43:55 PM »
Mission cover ( transmission / gear box cover)
Early head ( 1969 to 1972 )  ;)
I can tell its a early K0 to K2 by the fins.
