Author Topic: Swing arm bush fitting  (Read 581 times)
Offline Crispy
« on: July 12, 2019, 04:36:13 PM »
Hi All,
I'm just about to fit some new bushes into a powder coated K1 swing arm, they are a very tight fit , any tips on getting them in?  I've cleaned the swing arm of any excess powder coat ,I have bronze bushes and they're in the freezer at the minute, not sure if I should warm the swing arm up in case it mucks up the coating?
Re: Swing arm bush fitting
« Reply #1 on: July 12, 2019, 04:43:40 PM »
Just as your doing Mick, freeze the bushes and tap them in. I used a bit if 4 x 2 timber laid flat on the collar and used a hammer to tap them in. Worked a treat for me and mine were a very tight fit as well.
Offline Crispy
« Reply #2 on: July 12, 2019, 05:10:37 PM »
Cheers Julie, thanks for the reply, it gave me the confidence to 'tap' the bushes in, more like 'whack' in my case! With a lump hammer!   :o They're in though!
« Last Edit: July 12, 2019, 05:13:16 PM by Crispy »
Offline MarkCR750
« Reply #3 on: July 12, 2019, 07:13:57 PM »
Ha, yes I remember being pretty brutal getting the bronze bushes in on mine, the last couple of mm didn’t want to go but getting brutal fixed it 👍
Suzuki GT250A (Nostalgia)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
Offline gtmdriver
« Reply #4 on: July 13, 2019, 12:24:51 AM »
Like you I cleaned out the bore of the swinging arm and the bushes went in eventually but I found that the inner bore had contracted and I needed to carefully ream them to size before I could get the pivot pin to slide in.
Offline Crispy
« Reply #5 on: July 13, 2019, 12:15:48 PM »
Well I got the bushes in OK but the swing arm was binding in the frame because the collar didn't protrude past the bushes so I had to file some of the outer face of the bushes down until the collar  stuck out a bit more! I cleaned out the bore of the swing arm but not the outer edge, think that was where my problem was!  :-\ Seems to be ok now  :)
