Author Topic: 400/4 Crank Oil Seal  (Read 944 times)
Offline THUNDERDOWNUNDER
« on: July 19, 2019, 08:50:33 AM »
Opps , orderd oil pump seals to fix oil leak . Well after cleaning underside of pump ext just found oil is coming from lower crank cover Agh ! Having said that I find I have said crank oil seal ! DSS 91201-323-005P .Question is can I fit this seal without splitting crank cases ? Help !
Re: 400/4 Crank Oil Seal
« Reply #2 on: July 19, 2019, 09:29:13 AM »
Are you saying that the alternator housing is filled with oil and if so, clean it down with cutch and brake cleaner to see if it is coming from the crank seal or the lower plug o ring  ;)
« Reply #3 on: July 19, 2019, 10:11:39 AM »
Yep looks like it’s coming from altinator housing ! Will it need removing ? What is lower plug O ring thanks ?
« Reply #4 on: July 19, 2019, 10:20:02 AM »
Main oil gallery plug O rings.  294 in this pic. 291 the other end of the gallery on other side of casing.
« Reply #5 on: July 19, 2019, 10:33:42 AM »
Thank you I will have a look in the morning .Its night time here in Perth just now !
« Reply #6 on: July 23, 2019, 08:58:53 AM »
Yep  ,  Lower plug O ring is leaking .Has nurse Julie got any ?
« Reply #7 on: July 23, 2019, 09:15:05 AM »
Nurse Julie does have them 😀😀 When you change that one, its easier to change the one at the other end of the gallery also. Drain oil, remove nut on right side of gallery, put something long through the gallery and tap out the plug where your leak is (its a push fit plug, not threaded on the left side). Replace both O rings, make sure the push fit one is home very tight. Refill with oil. DO NOT start engine until you have replaced engine casing, as the casing pushes on the little tit on the push plug to keep in in place when crank pressure rises. If you don't fit cover, the plug will blow and you will have an almighty oily mess to clear up.
« Reply #8 on: July 23, 2019, 09:31:40 AM »
I got the plug out with long nose pliers. Not to much oil coming out .Left it overnight to drain . Just got to get in touch with Nure Julie ! Thanks for your help Guys !
« Reply #9 on: July 23, 2019, 09:31:57 AM »
As I found out  :o :o ;D
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #10 on: July 23, 2019, 09:35:01 AM »
« Reply #11 on: July 23, 2019, 09:36:42 AM »
If you managed to pull the plug out that shows how knackered the O ring is, the plug should be a very, very tight fit.
« Reply #12 on: July 23, 2019, 09:55:39 AM »
I thought it would be a good idea to remove some very light rust from the rotor by starting the engine and holding some 3000 grit wet and dry on it.
With hindsight and a bit of knowledge it was not such a good idea as I spent about an hour cleaning up the mess and rubbing the rust off manually ::) ::) ;D
« Last Edit: July 23, 2019, 12:43:28 PM by paul G »
Honda CB400 4
Honda CB750 UK K1
Online Bryanj
« Reply #13 on: July 23, 2019, 11:38:52 PM »
Just kicking it over to circulate oil makes enough mess!!!!
I have seen that plug put in backwards and they leak them, little pip faces outwards.
