Author Topic: 550 k3 grab rail  (Read 764 times)
Offline 3scs
550 k3 grab rail
« on: July 27, 2019, 10:57:29 AM »
Was just wondering would anyone know where I could get a rear grab rail for my 550 k3 mine has the f seat and rail fitted I’ve just acquired a k3 seat but it won’t fit because of the rail not as straight forward as I thought just removed grab rail to try seat and I think the rear light bracket is wrong also I think you were right trigg it should have the indicators mounted to rear light bracket so will looking for light mount also, it says it’s the same as 750k7
« Last Edit: July 27, 2019, 12:25:10 PM by 3scs »
Offline mickwinf
Re: 550 k3 grab rail
« Reply #1 on: July 27, 2019, 05:43:04 PM »
Hi Simon, that seat looks familiar! The k3 grabrail is very hard to find as it is only fitted to the k3, and the US type is different. here is a pic of the k3 that i had which has the correct rear light bracket, never did get the correct grab rail.
« Reply #2 on: July 27, 2019, 06:05:30 PM »
To change that rail, you will also need a different rear mudguard as well, as a tail light bracket.
Offline 3scs
« Reply #3 on: July 27, 2019, 08:25:06 PM »
yes thanks Mick you may be seeing a few more bits you recognise do you know what that grab rail was off because it looks ok
Offline 3scs
« Reply #4 on: July 27, 2019, 08:29:52 PM »
i think the way to go would be to get correct tail light assy first then try to find a rail if and when
Offline mickwinf
« Reply #5 on: July 28, 2019, 11:04:50 AM »
You will also need a k3 rear mudguard as it has a 3hole fixing for the light bracket. I cant remember what the grab rail came from but I had to modify it.
Offline 3scs
« Reply #6 on: July 28, 2019, 06:11:13 PM »
I’ve actually put the black plastic mudguard of yours on and drilled some holes a bit further down for now so I’m looking for a k3 grab rail and rear mudguard now !!
