Author Topic: Hello all  (Read 2136 times)
Offline PeterH
Hello all
« on: August 01, 2019, 06:04:00 PM »
I have a CB500 K04 American import,I am part way through the rebuild and I am replacing the switches on the handle bars. I purchased new switches from David Silver Spares and the right hand fits fine as per the old switch (peg in the switch fits into the bars and wiring is fed into them) this is an after market part.The left hand is another matter this was a Honda part supposedly for my machine there is no location pin to locate it on the bars and the wiring comes out of the face of the switch and does not go into the bars. I have been told this is the correct switch they do not list anything else. Has anyone else come across this problem.
Re: Hello all
« Reply #1 on: August 01, 2019, 06:17:11 PM »
Easy, its the wrong switch  ;) All K0 and K1 run inside the bars.
Offline PeterH
Switch
« Reply #2 on: August 02, 2019, 08:26:46 AM »
I have been told there is not another switch available.
Re: Hello all
« Reply #3 on: August 02, 2019, 02:44:07 PM »
Did you buy dfcfa-300-033p? The pictures for that one look correct.
Re: Hello all
« Reply #4 on: August 03, 2019, 08:27:56 PM »
What is wrong with the old original switches ?
If you have them , just refurbish them  ;) ;)
Re: Hello all
« Reply #5 on: August 03, 2019, 10:57:11 PM »
K0 didnt have the sidelight position on the rh switch just off/low/high it was later the yanks did away with the off position
