Author Topic: Still Running like a dog!!!  (Read 6945 times)
Offline jon stead
Re: Still Running like a dog!!!
« Reply #90 on: September 10, 2019, 08:06:38 PM »
Ok so local mechanic who has a good reputation has had bike for a day and is convinced this is a valve problem. Says he has heard similar sounds/symptoms on other bikes down to slightly bent valves that stick when warmed up.
Am now thinking that maybe I have accidentally slightly bent the 1 and 2 exhaust valves when I reassembled after the head gasket change.
This all seems logical as this problem only started after the head gasket change and am sure nothing else was changed, valve timing is correct.
Also thinking back I seem to remember I had a bit of a struggle getting the rocker cover to go on back easily even though I thought I had wound back the adjusters as far as I could.
Started another thread now as this is getting off track
If you have bent a valve whilst putting the rocker cover back on, it’s possible you’ve cracked a valve guide as well. I know because I did it! A very costly mistake.
Offline paulbaker1954
« Reply #91 on: September 11, 2019, 09:59:16 AM »
I guess with these bikes its all down to experience, if this turns out to be the cause as you say an expensive but very good lesson learned
« Last Edit: September 11, 2019, 10:31:40 AM by paulbaker1954 »
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
