Author Topic: 750K0 Lower Crankcase casting  (Read 844 times)
« on: August 07, 2019, 12:02:37 AM »
Anyone know what the purpose  of the 750K0 Lower Crankcase casting circled in red  is?
it appears to be  broken off at the top on my 69 K0 crankcase.
Re: 750K0 Lower Crankcase casting
« Reply #1 on: August 07, 2019, 01:43:20 AM »
I can only guess that it’s an oil guide vane to make the oil go to where the engineers wanted it as the crank rotates. The main bearing shell has a tang to locate it, so it can’t be that.
Is it not there in later engines?
« Reply #2 on: August 07, 2019, 05:35:36 AM »
They snap off a small bit at the top when the chain hits it, about 40 out of a 100 engines I do have it broken  ;)
« Reply #3 on: August 07, 2019, 08:27:26 AM »
Thanks Graham ... should I try to repair it or is it OK to leave it? There was no alloy bit in the engine when I drained it and the tensioner looked like it had recently been replaced... but I got a new one and chains just in case.
This is mine & the damage:-
« Reply #4 on: August 07, 2019, 09:46:17 AM »
Generally things like that are part of "windage " mitigation that engine designers use.  It's to try and peel off excess oil from rotating crankshaft to prevent a rotating oil mass building up round the crank.
Where oil comes back down from the head it drops onto the crank more than other extremes of crankcase, so it tries to seperate it to push it down toward the sump usually.  A bit like a potatoe peeler.
Offline UK Pete
« Reply #5 on: August 07, 2019, 10:02:10 AM »
Wow some very knoledgeable answers
Btw I received my chains ash, thankyou very much
« Reply #6 on: August 07, 2019, 10:35:56 AM »
I agree with you Pete and it's the reason why I need my daily fix of the forum 😊. Always a great read, intresting threads, fantastic rebuilds and a good bit of friendly banter. It's like meeting your mates in a Weatherspoons but without the punch-ups😉!
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #7 on: August 07, 2019, 11:02:33 AM »
I have found that they do nothing at all. I never repair them and have never had a problem. And it is always the same size and shape  ;)
My theory is that Honda put it in the casting so, if your chains go loose then it chips the bit off and you find it in the sump. Just a reminder that your chains and tensioner need replacing  ;)   ;D ;D ;D
« Reply #8 on: August 08, 2019, 07:53:23 AM »
Or it could be that Mr Honda put it there so when it did break it clattered round the engine, wrecked a bucket load of stuff and you spent thousands in the dealership getting all the damage repaired.
Alas for Mr Honda he didn't get his sums right and it just dropped to the bottom of the engine instead, which just goes to show, Mr Honda didn't always get things right.  ;D ;D
Ah but what about the bikes down under it would make a mess of them ! ;)
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #9 on: August 08, 2019, 08:10:53 AM »
Ah but it wouldn't have snapped it off in the first place with the chain hanging upside down  ;D
« Reply #10 on: August 08, 2019, 09:18:20 AM »
;D ;D
Honda CB400 4
Honda CB750 UK K1
