Author Topic: Normal fuel consumption for 550K1  (Read 1562 times)
Offline Erny
  • CB750K7 CB550K1
« on: August 31, 2019, 08:25:25 AM »
I want to xcheck, what's your normal fuel consumption on 550K (K1)?
After weekend spent with 550 I can say I can do 125 miled per 10 liters of gasoline.
That gives 5L/100km.
Was riding alone with light luggage on rear seat
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline flatfour
Re: Normal fuel consumption for 550K1
« Reply #1 on: August 31, 2019, 08:44:34 AM »
Mine always returned around 45 mpg ridden normally, i.e. upward changes through the gearbox at around 6,000 rpm and cruising at legal limits (usually 5,000 rpm on the open road). This figure hasn't varied over some 14 years in my ownership.
Strangely enough, my CB750 K2 returns the same mpg at the same speeds, although both upward changes and cruise rpm are lower, as you might expect.
Perhaps even more odd is that my BMW K1300GT returns over 50 mpg under the same conditions, usually ridden two - up.
Offline peterengland
« Reply #2 on: August 31, 2019, 09:03:56 AM »
I get about 58 mpg from mine but shift well before 6,000 rpm
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #3 on: August 31, 2019, 09:12:31 AM »
Erny, approx 4.5 litres to our gallon so you can convert/compare - as posts quote in 'mpg' means miles per gallon.
Offline davefirestorm
« Reply #4 on: August 31, 2019, 09:29:24 AM »
My 550 F2 was thirsty at times getting as low as 27mpg!! Two up loaded with camping gear and thrashing it,can’t remember exactly but around 45 mpg could be achieved in contrast my mate had a 550 K3 with the lean burn carbs fitted and he’d record 65 +mpg,both bikes were new 1977 models
Honda CB650Z
Honda F6C Valkyrie
Offline Erny
  • CB750K7 CB550K1
« Reply #5 on: August 31, 2019, 09:34:53 AM »
Then I'm fine, it looks to be 56.5 mpg
And yes, my K7 750 consumers practically the same (we were together doing the same 900km route). And my GS1200LC also!
« Reply #6 on: August 31, 2019, 09:41:36 AM »
I rarely ride mine 'sensibly' as I'm usually racing with Trig and still get mid 40's mpg. I would expect low to mid 50 mpg if I just rode normally.
« Reply #7 on: August 31, 2019, 12:10:27 PM »
I honestly believe "smiles per gallon" is far more important than miles per gallon! Unfair to compare these old bikes to modern multi valve ultra lean running stuff, and fuel injection on some big bikes can make ours look like eco disasters. But if you were worried about mpg you'd ride a Honda 90 (180-220 mpg) or even drive an eco friendly car! :o
« Reply #8 on: August 31, 2019, 12:15:12 PM »
Beat me to it Hairy.
When asked about mpg my usual answer is “I don’t care”
2022 Tiger Sport 660
« Reply #9 on: August 31, 2019, 12:33:07 PM »
My 500 17 km on 1 liter.
« Reply #10 on: August 31, 2019, 01:44:40 PM »
Don't know, don't care.  It's cheaper to run than the car by a long way.
Offline Erny
  • CB750K7 CB550K1
« Reply #11 on: August 31, 2019, 04:03:57 PM »
Just to make it very clear, normally i don't care too! When I ride I enjoy, if I want to race I do either I go just to enjoy wind.. Never cared about cons, except I havre almost empty tank and petrol station is far away
I just asked to verify carb settings (mixture) is +/-
« Reply #12 on: August 31, 2019, 04:09:55 PM »
Oh... there's a simple trick. When tank is empty, almost lie down your bike to the left side. A lot of petrol will take the hurdle in the middle of the tank and flow over to the left side. Enough to do another 10km. I have done this a couple of times and it always worked.
Offline Erny
  • CB750K7 CB550K1
« Reply #13 on: August 31, 2019, 06:30:45 PM »
Heh, this trick I know pretty well, saved me with my 750 K7 twice, but trird time did not helped, petrol was barely for 2km only and I ended up in the middle of the highway bridge in Bratislava, right at morning peak traffic, creating big traffic jam
Fortunaty my collegue coming by saved me after I called him to bring bottle of gasoline,
« Reply #14 on: August 31, 2019, 07:54:36 PM »
What is normal when it comes to fuel consumption  ::)
All you have to do is every time you fill up, turn the clock back to 0 and then when you get to 100 miles, fill up again and 0 the clock. You will then never run out of fuel  ;) ;)
