Author Topic: K1 brake wire rating?  (Read 410 times)
Offline Andrew-S
« on: September 05, 2019, 02:29:23 PM »
Hello folks,
One of the wires to the hydraulic front brake switch on my K1 is pulling/fraying away from its bullet connector/plastic sheath as the wires were pretty tight. So I need to do some repair work to both connectors and lengthen the wires slightly and want to reuse the original connector/sheaths - can some please advise to the wire rating?
Thanks,
Andrew
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline Andrew-S
Re: K1 brake wire rating?
« Reply #1 on: September 05, 2019, 02:58:31 PM »
Found it!  - the rating is stamped on the black wire: 0.75  ::)
1976 UK Z900 A4
2018 BMW R1200 GS
