Author Topic: Fitting Lower Tank Trim Strips  (Read 538 times)
Offline Andrew-S
« on: September 18, 2019, 09:42:21 AM »
The original lower tank trim strips on my K1 are a bit too brittle and cracked in a couple of places (particularly one side) to refit against Menno's lovely new paint - although I am considering it as they have aged nicely, unlike me.......
I have bought replacement replicas from DS which are not quite the same profile, but if I do use them I assume these are easily moulded using the tank brackets - the question is: do I also use heat from a hairdryer or is this not needed?
Thanks,
Andrew
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Re: Fitting Lower Tank Trim Strips
« Reply #1 on: September 18, 2019, 10:05:32 AM »
Andrew, mine went on fine with no heat just following the contour of the tank.
You may need to trim them to fit as I did.
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Offline Andrew-S
« Reply #2 on: September 18, 2019, 10:17:39 AM »
Thanks Paul.
1976 UK Z900 A4
2018 BMW R1200 GS
