Author Topic: Cleaning Engine Internal parts.  (Read 1333 times)
Offline Man Of Kent
« on: October 03, 2019, 04:30:08 PM »
Afternoon all,
I have been given quite a few boxes of 400/4 engine parts, the chap had stripped down about 3 engines. A lot of the parts has got slight surface rust. My question is what is the best method in cleaning them up, I am cautious in using abrasives as being machined engine parts. My thought was too soak them in diesel then use a old tooth brush, degrease them to wash off the diesel. Then give the a light spray of oil and bag up in poly bags.
I would really like to know what you experts suggest.
Cheers Dave
« Last Edit: October 03, 2019, 04:48:50 PM by Man Of Kent »
Re: Cleaning Engine Internal parts.
« Reply #1 on: October 03, 2019, 06:16:33 PM »
You can clean the parts in an ultrasonic bath with a suitable cleaning solution. Look at the Allendale Ultrasonic site (both on the Web and on ebay). They send the cleaning solution P&p free.
Personally I wouldn't re-use roller bearings if they have any rust on them.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #2 on: October 03, 2019, 06:25:58 PM »
Thats more than slight surface rust.....  :o . Use a paperweights only, unless you are absolutely desperate for the spares.
« Reply #3 on: October 03, 2019, 06:35:54 PM »
I have seen a lot, lot worse but unless they are very rare, totally unobtainable parts, which they aren't, I wouldn't even bother. Surface / flash rust is ok to clean up but not rust that deep, the parts won't function correctly by the time you chisel off the rust.
Offline Man Of Kent
« Reply #4 on: October 03, 2019, 06:45:48 PM »
I think the pictures makes the rust look worst than it is, but is diesel ok to use or should I be using other chemicals?  :-\
« Reply #5 on: October 03, 2019, 06:54:25 PM »
Oh yes, photos do make rust look pretty horrific, I forgot about that 😀 If you think they are salvageble, a good soak in diesel and a scrub with a brush will be fine. Don't wash the diesel off after cleaning as it will leave a nice film of oil as protection. Then just bag up.
Offline Man Of Kent
« Reply #6 on: October 03, 2019, 06:58:57 PM »
Cheers Julie, I shall give it a go and see what happens.  ;D
« Reply #7 on: October 03, 2019, 07:02:57 PM »
Always worth trying to save parts. You will know if they are beyond saving if you see any obvious damage or pitting in the metal after cleaning.
« Reply #8 on: October 03, 2019, 08:29:54 PM »
The problem with any rust removal is, that the part becomes unbalanced  ;)
