Author Topic: Boyer micro ignition  (Read 1227 times)
Offline Erny
  • CB750K7 CB550K1
« on: October 20, 2019, 01:32:11 PM »
Just installed this ign (using stock coils), first results are promising. My strobe light failed, so cannot set it finally,but will go for test ride.
Those you have this installed (Paul?), where you placed your unit on the bike? Looks to me good place is on battery, but will require some additional work while removing or changing battery.
CB750K7 US model (1977)
CB550K1 US model (1975)
Re: Boyer micro ignition
« Reply #1 on: October 20, 2019, 02:40:30 PM »
My strobe light failed...
Have you tried flipping that inductive pick-up. There's polarity to be observed!
Quote
I have had my homebuilt ign located there for decades (see pic). There's quite some space between the battery and the sidepanel. Well shielded and no vibrations. I usually have to renew the battery every seven years, so no big problem.
« Last Edit: October 20, 2019, 02:45:11 PM by deltarider »
Offline paulbaker1954
« Reply #2 on: October 20, 2019, 05:27:17 PM »
I changed for the full kit inc the micro coils so mounted the box above the original coil mounting bracket and used some aluminium section for the new coils so different set up to yours
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline jon stead
« Reply #3 on: October 20, 2019, 06:34:31 PM »
I copied Paul’s installation and put the Boyer unit under the tank with the new micro coils bolted on alongside.
Offline Erny
  • CB750K7 CB550K1
« Reply #4 on: October 20, 2019, 08:04:53 PM »
Quote
I place is practically identically as you, first try was also under rubber band but as I'm not sure I'll keep it after testing and do not want to make band too big, decided to use cable ties aroud battery.
Ad strobe - it was working first few seconds then died (light only)...
Offline Erny
  • CB750K7 CB550K1
« Reply #5 on: October 20, 2019, 08:09:37 PM »
After testing (170km today):
On postitive side:
- despite no chance to set it by strobe, engine starts and runs well, revs very good.
- seems previous issue in low RPM is almost gone (weak springs on advancer?)
On negative:
- seems to me this ignition consumes more energy (like well known Dyna-S), 0.5-0.7 less voltage with this ignition. Anyone can confim?
« Reply #6 on: October 20, 2019, 08:29:44 PM »
some very nice mountings there,
 I mounted mine on the LH downtube,along side the horn,
 you could try adjusting the timing this way,
warm the motor,then loosen the fibre disc,and move anti clock wise ,the engine revs may rise,see how it runs and starts .
the Boyer has an automatic advance/retard .
when you strobe it,do it at 4,500 rpm
Offline Erny
  • CB750K7 CB550K1
« Reply #7 on: October 20, 2019, 08:33:16 PM »
Didn't you observe higher power consumption after its installation?
