Author Topic: Would you buy this engine ?  (Read 1394 times)
« on: November 04, 2019, 07:21:12 AM »
https://www.ebay.co.uk/itm/1970-KO-Honda-CB750-CB-750-Engine-1576-FREE-SHIPPING-TO-ENGLAND-UK/372825252821?hash=item56ce1de3d5:g:IlIAAOSwVkBdvHVA
I can see chain damage and the top and bottom cases maybe welded together, see blue shite on the crank case surfaces  :o
Offline Moorey
Re: Would you buy this engine ?
« Reply #1 on: November 04, 2019, 12:28:05 PM »
No. It's not even a decent weld and looks to be full of inclusions and does look to have run into the top case. So the engine wasn't split to do that. I don't think the cases would be hard to split though. The blue sealant from some other repair and the mixture of fasteners and its a miss from me. A lot of unknowns for £1000
Offline steff750
  • THE POWER OF DREAMS
« Reply #2 on: November 04, 2019, 06:11:23 PM »
 ;) no not likely to much money for my piggy bank i stopped buying sohc engines when they went over the two hundred quid barrier
Quote
i had the same problem once only discovered it when the final drive bearings gave out ,not a job for the faint hearted when using a grinder to split the weld them gears are almost touching the repaired area so could be a challenge  :o
Offline UK Pete
« Reply #3 on: November 04, 2019, 06:26:43 PM »
If it were a 69 engine then may be but this is the  k1 engine  not so desirable
Sent from my SM-G950F using Tapatalk
Offline steff750
« Reply #4 on: November 04, 2019, 09:32:43 PM »
 ;) and i thought it was sandcast 1576  for what hes asking for it. but on checking again its a k0 just goes to show if the price is to high nobody pays too much attention to it 8)
