Author Topic: Disc interchanageability  (Read 1998 times)
Offline Seamus
« on: March 02, 2009, 09:36:52 AM »
Probably not even a word, but i hope you know what I mean.
I bought another disc for my K1 and it is a good bit bigger in diameter. I think it was from a 76 bike. I thought that the front disc was the same throughout the K series. Did Honda change the disc size at some time? Any idea which models had yje larger disc?
Seamus
Re: Disc interchanageability
« Reply #1 on: March 02, 2009, 02:39:00 PM »
As far as i know 750 had the same diameter 69 to 76. the 500/550 was smaller has somebody fitted one of those front ends as the tubes are the same diameter? Pics might help
Offline Seamus
« Reply #2 on: March 02, 2009, 07:43:15 PM »
Thanks for the reply. I measured the discs, my one is 275mm and the replacement is 295mm.
The picture shows the setup before I took it all to bits.
Does the disc look small in this pic?
« Reply #3 on: March 02, 2009, 09:00:31 PM »
That gap looks very big.
On my 500, the gap between the outer edge of the disc and the caliper is only 1-2mm
2022 Tiger Sport 660
Offline Seamus
« Reply #4 on: March 02, 2009, 10:40:06 PM »
Thanks for the info. I will have to check when I start the rebuild. The frame and other bits are off being powder coated and some other bits being chromed.
I may be able to test the disc on the wheel against the fork leg with the caliper in position.
Apreciate the help
Seamus
« Reply #5 on: March 03, 2009, 01:48:39 PM »
Caliper and bracket are 750, gap is way too big i suspect a 500 disc, or more likely a complete front wheel due to accident. what are the markings on the rim and check against a known 750 one as the 500 is narrower
Offline Seamus
« Reply #6 on: March 03, 2009, 05:22:47 PM »
Thanks for the info. Just rebuilt the front wheel with a new rim (750). I still have the old one and will measure when I get home for comparison.
Was the hub the same for both bikes? as the speedo plate and drive etc match the workshop manual diagrams.
Seamus
Offline Seamus
« Reply #7 on: March 05, 2009, 10:42:58 PM »
Measured the rims and they are both the same. Guess it was a replacement disc
for the help
Seamus
