Author Topic: Spark plug re-theading .. can anyone recommend a decent repair kit?  (Read 786 times)
Can anyone recommend a spark plug repair kit for 14mm plugs? Some very cheap ones on eBay but not sure how good they will be. I have got a really nice CB250K0 cylinder head but one plug thread is stripped.
Re: Spark plug re-theading .. can anyone recommend a decent repair kit?
« Reply #1 on: November 08, 2019, 06:16:25 PM »
here's an old thread Ash that may be of use?
http://www.sohc.co.uk/index.php/topic,19283.0.html
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Moorey
« Reply #2 on: November 08, 2019, 08:42:03 PM »
Now nearly 2 1/2 years on and still OK, but must admit its not had much use this year due to new hip.
I used the Vorlux kit but the US PRO looks to be exactly the same kit.
« Last Edit: November 08, 2019, 08:58:13 PM by Moorey »
Offline matthewmosse
« Reply #3 on: December 28, 2019, 02:13:28 PM »
I used a vorlux kit on a Kohler lawnmower engine last summer, only issue, if you dont centre punch the insert or similar to retain it the insert comes out on the plug - mildly annoying if you aren't paying attention.  Actually came with 4 inserts of varying length so potential  for 4 plug threads repaired depending on length required. Otherwise a nice quick cheap and easy repair.
Offline Moorey
« Reply #4 on: December 28, 2019, 06:34:50 PM »
I put a drop of stud lock on mine and it's never moved. Between head and insert not between plug and insert.
