Author Topic: 400/4 Battery not charging  (Read 3585 times)
Offline THUNDERDOWNUNDER
Re: 400/4 Battery not charging
« Reply #45 on: December 18, 2019, 11:24:15 AM »
With the Regulator bolted to frame what is the colour from Top to Bottom do the three wires from Loom go Thanks ?
Offline Moorey
« Reply #46 on: December 18, 2019, 12:01:47 PM »
Just to cheer you up it was 2 degrees in the garage this morning.  :)
« Reply #47 on: December 18, 2019, 09:55:36 PM »
Green white black wires to unused regulator ? Weather here Down Under is still Hot . 2 degrees would be welcome here for half an hour !
Offline Andych
« Reply #48 on: December 18, 2019, 10:16:16 PM »
Just to add to the weather mix... temp in outer Sydney today will be 44 degrees and they are expecting record temps of over 50 Celcius in multiple places between Perth and Sydney...
And I am spending the afternoon outside working.. Living the Dream :)
1975 CB400 - Project
1978 Yamaha SRX250 - Project
« Reply #49 on: December 19, 2019, 02:54:23 AM »
Mission Accomplished . Battery charging now . Thanks for all your help guys I couldn’t have done it without you . Just off for a ride in the Heat Agh!
« Reply #50 on: December 19, 2019, 08:09:12 AM »
So what cured the issue out of interest  ;)
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Offline mattsz
« Reply #51 on: December 19, 2019, 03:46:25 PM »
Seriously - after four pages of tests, don't leave us hanging!!!  ;D
« Reply #52 on: December 20, 2019, 09:46:44 AM »
Well , after testing A/C Generator which was OK . Testing regulator/Rectifier which was fine it turned to wiring from Loom to generator . The three yellow connectors needed a good clean and the green and white wires one was broken so after cleaning and soldering . Alls well how’ve battery is charging .It was a good learning curve . So thanks again guys and a big thank you to BryanJ .
Offline Moorey
« Reply #53 on: December 20, 2019, 09:55:08 AM »
Nice talk through Bryan.  ;)
Offline mattsz
« Reply #54 on: December 20, 2019, 10:05:41 AM »
