Author Topic: CB750F2 Brake Caliper  (Read 1121 times)
Offline SteveCR7
« on: November 27, 2019, 09:23:42 PM »
Hi, can anybody tell me the distance between the mounting hole centres on an F2 caliper where it bolts to the carrier:
Thanks Steve
76 Rickman CR750 (resto in progress)
73 Kawasaki H1D (sunny day madness)
02 Triumph Sprint ST955 (commuter and long distance)
Offline SumpMagnet
Re: CB750F2 Brake Caliper
« Reply #1 on: November 27, 2019, 10:49:35 PM »
I can dig mine out tomorrow and give them a message. Fronts?
Mine are all in pieces in the shed...so it's easy to measure
CB750F2 - in pieces
Offline SteveCR7
« Reply #2 on: November 28, 2019, 12:49:06 PM »
Thanks sumpy, yes front caliper
Offline SumpMagnet
« Reply #3 on: November 28, 2019, 10:28:54 PM »
Will get out there and measure. Sorry...didn't get to do it today but I am out of work early tomorrow.
CB750F2 - in pieces
Offline SumpMagnet
« Reply #4 on: November 29, 2019, 06:14:10 PM »
Right...checked the measurements and here's the info.
Threaded mounting holes where the carrier attaches to the fork lowers are 10mm diameter holes, 65mm between centres.
The holes where the caliper bolts to the carrier are 90mm between centres as best I can measure it.
CB750F2 - in pieces
Offline SteveCR7
« Reply #5 on: November 30, 2019, 09:39:20 AM »
That’s great, thanks for the info. The really good news is the Lockheed caliper I am looking to fit has mounting hole centres of 89mm, so will look at feasibility of fitting Lockheed to F2 carrier.
Cheers Steve
Offline SumpMagnet
« Reply #6 on: November 30, 2019, 12:50:55 PM »
Allowing for my measurements being potentially off by a small amount....I had to use a steel rule as I don't have verniers that go that far...I reckon there is a very good chance they will drop on with no problems
CB750F2 - in pieces
Offline SteveCR7
« Reply #7 on: November 30, 2019, 01:20:47 PM »
It will just depend on the clearance around the caliper and alignment to the disc. Fingers crossed!
