Author Topic: Petcock wanted  (Read 676 times)
Offline paulbaker1954
Petcock wanted
« on: December 17, 2019, 11:48:56 AM »
Anyone happen to have a good functioning one they are prepared to part with for some suitable recompensation?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Petcock wanted
« Reply #1 on: December 17, 2019, 12:07:13 PM »
For what Paul !
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Offline Erny
  • CB750K7 CB550K1
Re: Petcock wanted
« Reply #2 on: December 17, 2019, 12:21:33 PM »
Paul,
don't know what type you have, please specify
For my 550 K1 - NOS 16950-374-671 with dual output are really expensive. For the first try I first get NOS with sigle output but after some time started to leak after ~1 month. Then I bought replica one from 4into1 https://4into1.com/petcock-20mm-x-1-5mm-16950-374-671-cb550-1975-1976/. But even this started to leak after few weeks. I now suspect root cause of this is degrading kreem liner in my tank (PO applied it wrongly on corroded surface) that decomposes into particles, some very small (like small sand grains) that passes via strain to petcock (and make it leaking) and then reach carb float valves (blocking them to close). All in all, I have petrol leak in garage floor  >:(... My next step is to remove liner from tank and remove corrosion.
Pics are showing what comes out of tank each time I flush it and how it looks like inside...
CB750K7 US model (1977)
CB550K1 US model (1975)
Re: Petcock wanted
« Reply #3 on: December 17, 2019, 01:50:27 PM »
For what Paul !
500 four K0
Re: Petcock wanted
« Reply #4 on: December 17, 2019, 04:57:58 PM »
They are still available new and same as 750. Dont forget the sealing washers under the screws, generic fibre are too thin and split
Re: Petcock wanted
« Reply #5 on: December 17, 2019, 05:27:25 PM »
I checked DS, anyone tried their aftermarket one? (please no Bitsa comments!!!!)
Re: Petcock wanted
« Reply #6 on: December 17, 2019, 06:36:06 PM »
Everyone I have fitted, I have had to put a new seal kit in after a while  ;)
Re: Petcock wanted
« Reply #7 on: December 17, 2019, 09:06:13 PM »
Sorted now thanks to fellow member from Lytham👍👍
