Author Topic: Stiff clutch  (Read 1244 times)
Offline masonmart
Stiff clutch
« on: December 17, 2019, 07:39:15 PM »
It's been asked before but I have a newly assembled Dresda CB500 and I can hardly pull in the clutch. I could never take the bike out as it is because I wouldn't be able to change gear after about the first two changes. Is this normal and is there any possible way that I can somehow improve it?
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Re: Stiff clutch
« Reply #1 on: December 17, 2019, 07:47:28 PM »
The clutch should be light and easy.
Check the cable. Make sure its not  corroded. And no tight curves.
Grease the worm drive with HMP grease.
Has it been fitted with over strong springs?
Offline Erny
  • CB750K7 CB550K1
Re: Stiff clutch
« Reply #2 on: December 17, 2019, 08:11:02 PM »
Clutch on my 550K1 goes very smooth and light (I use 2 fingers), engine never opened and clutch does not slip
I suppose 500 is similar
CB750K7 US model (1977)
CB550K1 US model (1975)
Re: Stiff clutch
« Reply #3 on: December 17, 2019, 08:16:05 PM »
I  think the 550 clutch has a different operating system.
The cable fixes on the same side as the clutch.
But the 500 fixes by the gearbox sprocket. And pushes a rod through the gearbox shaft.
Re: Stiff clutch
« Reply #4 on: December 17, 2019, 09:12:06 PM »
Dresda supplied,  when contemporary,  clutch springs that were higher rated than standard for all the Honda 4 cylinder engines. You may need to check the spec that's in there to assess what you're starting with.
They do make the clutch heavier by quite a noticeable amount.
Normally I'd change bike gearboxes without using the clutch generally if it's setup well.
Re: Stiff clutch
« Reply #5 on: December 17, 2019, 09:23:14 PM »
Correct routing of the clutch cable is paramount. Have you set the play of the lifter as prescribed? Is it greased? BTW, forget about the play at the lever as prescribed by Honda, but rather follow Hondaman's advice in: http://forums.sohc4.net/index.php/topic,165583.msg1914790.html#msg1914790
I've adjusted my clutch thus, that there's hardly any play at the lever with engine cold. When the engine is hot, I have more or less the play Honda prescribes. Works fine for me. I never had a problem with the rod, nor with the adjuster/lifter. When working on them, don't loose/omit the steel ball inside the lifter!
« Last Edit: December 18, 2019, 09:17:17 AM by deltarider »
Re: Stiff clutch
« Reply #6 on: December 18, 2019, 12:51:08 AM »
If it has "drop" type bars the clutch will never be light
Offline masonmart
Re: Stiff clutch
« Reply #7 on: December 18, 2019, 10:37:14 AM »
Thanks Bryanj. The bars are raised a couple of inches but the frame isn't standard but a compact Dresda frame so it could be cable?
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Re: Stiff clutch
« Reply #8 on: December 18, 2019, 11:08:20 AM »
You may have to use the cable US CB500 models had. They had raised handlebars compared to European models. Consult Parts Lists, DS or CMSNL for the part numbers involved.
Re: Stiff clutch
« Reply #9 on: December 18, 2019, 11:56:13 PM »
You would only need the US cable if the bars are about 4 inch higher than UK ones
Re: Stiff clutch
« Reply #10 on: December 20, 2019, 03:55:01 PM »
Funny, the CB500 clutch topic runs on the UK, the German and the French site simultaneously. Maybe it is interesting to measure and compare length of the CB500 as well as the CB550 lever arm (engine side).
Offline masonmart
Re: Stiff clutch
« Reply #11 on: December 20, 2019, 07:08:15 PM »
I've found at least part of the problem. With the clutch adjusted at the cover end as per the manual, the actuating lever in the casing is at around 45 deg at the start of pulling the lever in and vertical when the bar lever is at full travel. This increases the force needed by a very large amount (as above). I disassembled the actuating assembly, re-assembled it and readjusted it and it does exactly what it should. Still heavy but massively better. I'm not sure exactly what I did but I must have done it wrong when I first did put it together. The cable routing needs sorting out and maybe the length reducing to keep it straight.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline masonmart
Re: Stiff clutch
« Reply #12 on: December 22, 2019, 05:42:29 PM »
Perfect now.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
