Author Topic: Engine Strip - I'm nervous  (Read 3788 times)
Re: Engine Strip - I'm nervous
« Reply #30 on: January 07, 2020, 10:44:30 PM »
Believe it not Graham, even though mine had been installed wrong at the factory and the shell was split, it ran as smooth as it should and the shaft was perfect. It had done over 45,000 miles on that bearing.
The housing is only a housing, if the pins are badly worn then, the shaft is damaged  ;)
It is the pins that are in contact with the shaft, not the cage or the housing
« Last Edit: January 07, 2020, 10:49:57 PM by Trigger »
Offline waffey
« Reply #31 on: January 08, 2020, 06:37:11 PM »
Trigger, it all seems fine. I was going to replace as I had the gearbox apart. I'll re use them. I've ordered two replacement bearings than run in the gearbox though they seemed fine.
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
« Reply #32 on: January 08, 2020, 07:08:53 PM »
You old boys worry too much.
 If gear box bearings are good then just reuse them. I only change gear box bearings when they have play or have gone rusty from standing   ;)
Offline waffey
« Reply #33 on: January 10, 2020, 05:41:53 PM »
hi,
I've had to take the crank case topto an engineering to remove the cam chain adjust bolts. Can some tell the size of the bolt so they can drill out, retap etc
items 177 and 219 I need dimensions for or does anyone have parts I could purchase before I go source new?
they are also removing the bottom e
« Last Edit: January 10, 2020, 05:58:12 PM by waffey »
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #34 on: January 10, 2020, 06:43:13 PM »
219 has an m6x1 thread in the crankcase, maybe im blind but cant see a 177
Offline waffey
« Reply #35 on: January 11, 2020, 12:38:23 AM »
sorry I cut 177 off
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #36 on: January 11, 2020, 07:02:38 AM »
Never checked that one but i suspect m6x1 same as the adjuster bolt
NB remeber the adjuster bolt is a "special" as there is a bit of m8 thread under the head for the lock nut
Offline waffey
« Reply #37 on: January 12, 2020, 05:23:22 PM »
does anyone have an adjuster bolt to sell?
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #38 on: January 12, 2020, 05:44:05 PM »
Do you want this rocking horse poo ready chromed?
There was somebody making them, not sure if it was ttr 400
« Reply #39 on: January 12, 2020, 05:51:10 PM »
Yes, Kevin, TTR400 makes them and a thing of beauty they are too ( not that I have one that posh fitted)
http://www.ttr400.com/photo_3.html
« Reply #40 on: January 12, 2020, 05:57:39 PM »
If you cant get that try
http://noxandrattles.co.uk/index.htm
Offline waffey
« Reply #41 on: January 12, 2020, 08:16:34 PM »
much appreciated, two new websites I didn't know existed  8)
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Offline waffey
« Reply #42 on: January 16, 2020, 11:30:07 AM »
Hi,
just had one of the pistons measured and looks like a standard 51mm piston. As suggested before, do I got straight in the 0.50 mm over size for a rebore or the 0.25mm?
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #43 on: January 16, 2020, 11:38:28 AM »
Hi,
I would suggest go straight to +.50
Offline waffey
« Reply #44 on: January 16, 2020, 11:52:11 AM »
always take the advice of a nurse ;
Thanks Nurse Julie
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
