Author Topic: Engine Strip - I'm nervous  (Read 3769 times)
Re: Engine Strip - I'm nervous
« Reply #45 on: January 16, 2020, 01:30:19 PM »
always take the advice of a nurse ;
Thanks Nurse Julie
Do you know what the piston to bore clearance is at present?  It depends on what the clearance is as to what size over you need to go. It's no good going +. 50 if the bores are already worn up to near, or over . 50 already. I'm assuming the clearance is well within spec at present 🤔
« Last Edit: January 16, 2020, 01:32:14 PM by Nurse Julie »
Offline waffey
« Reply #46 on: January 16, 2020, 06:45:28 PM »
Nurse, nurse...….yes, its an assumption that the bores are ok, I need to somehow beg, borrow or steal a measuring device to check the internals.
next on my slop chit. I still cleaning bits and bobs and have to make a place for the frame which should be due back by the end of the month.
gotta work on the TL soon as well...….
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
« Reply #47 on: January 16, 2020, 06:50:47 PM »
If you come past gloucester i will measure it for you
« Reply #48 on: January 16, 2020, 07:18:20 PM »
Ditto.... But I doubt you will be passing Lincolnshire 😁😁😁
Offline waffey
« Reply #49 on: February 15, 2020, 10:46:15 AM »
Help, how do I remove the in neutral switch from the casing?
« Last Edit: February 15, 2020, 10:58:48 AM by waffey »
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #50 on: February 15, 2020, 10:53:55 AM »
You are joking... aren't you? 😁
The photo shows the camchain tensioner bolt. 😕
Offline waffey
« Reply #51 on: February 15, 2020, 10:57:17 AM »
oooppsssss, just testing, new picture added  :-[
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #52 on: February 15, 2020, 11:33:02 AM »
It just pulls out.
Offline waffey
« Reply #53 on: February 15, 2020, 06:13:26 PM »
Thanks Nurse Julie
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #54 on: February 15, 2020, 09:55:19 PM »
It'll be stiff because of the O ring.
