Author Topic: Bomber fork leg  (Read 1365 times)
Bomber fork leg
« on: January 06, 2020, 04:24:19 PM »
Just stripped the forks for the Bomber after finally getting the seal holders off. This is what I found underneath, got to be the worst corrosion I have ever seen on a fork leg. It measures about 12 thou deep so is probably way outside rechroming limits. Don't suppose anyone has a spare fork tube for a Black Bomber CB450K0 going spare. Once again it appears to be a big ask.
Online AshimotoK0
Re: Bomber fork leg
« Reply #1 on: January 06, 2020, 04:30:28 PM »
Probably got one Roy but it will need rechroming.... no way as bad at that one though .. Will look tomorrow for you
Re: Bomber fork leg
« Reply #2 on: January 06, 2020, 04:33:49 PM »
Ash to the rescue yet again. They are going off to philpotts anyway but that ones going in the scrap. I think this build would be impossible if it wasn't for your stash. Cheers Ash.
Online AshimotoK0
Re: Bomber fork leg
« Reply #3 on: January 06, 2020, 08:25:02 PM »
Here ya'go Roy. Should rechrome fine.
I will get it off to you ASAP.
I just noticed on these that the Bomber stanchion waists slightly above the Bottom yoke. Did you notice that on yours?
Cheers "Ash-From-The-Stash"  ;D ;D
« Last Edit: January 06, 2020, 08:27:18 PM by AshimotoK0 »
Re: Bomber fork leg
« Reply #4 on: January 07, 2020, 07:40:35 AM »
Thanks Ash looks better than the one I have. Yes they do angle in above the yoke. Not sure Philpotts are going to like these as there are different diameters, angles, and several circlip grooves to be ground back in. Might be pricey. I will drop some cash into your Paypal account for postage of the growing list of parts. Thanks again.
Online AshimotoK0
Re: Bomber fork leg
« Reply #5 on: January 07, 2020, 08:38:57 AM »
Dont worry about post. The CB750K0 stanchions have the same arrangement of circlips so I don't think it will be a problem for Philpotts. Is it's a problem for them, there is also another place my friend Graham Curtis always uses in Nottinghamshire and they do a really good job too and a bit cheaper I believe.
Re: Bomber fork leg
« Reply #6 on: January 07, 2020, 03:56:31 PM »
Who are the other people in Nottinghamshire? I am always up for saving a few bob where possible. MCTID has recommended a place in Sandbach Cheshire called Dynasurf?
Re: Bomber fork leg
« Reply #7 on: January 08, 2020, 08:47:13 AM »
Ash. Have put a few bob in you Paypal account to cover the postage costs. Thanks again.
Online AshimotoK0
Re: Bomber fork leg
« Reply #8 on: January 08, 2020, 06:14:07 PM »
Very kind but you didn't need to Roy.... you are in credit for the next shipment now  ;D
Online AshimotoK0
Re: Bomber fork leg
« Reply #9 on: January 08, 2020, 07:29:09 PM »
Got this back from my buddy Graham Curtis ..
£130 if you deliver & collect.
Hard Chrome Plating Ltd 07860235709
« Last Edit: January 08, 2020, 07:36:44 PM by AshimotoK0 »
Online AshimotoK0
Re: Bomber fork leg
« Reply #10 on: January 08, 2020, 07:40:15 PM »
HARD CHROME PLATING & GRINDING
01623 237858
AND FORKS RECHROMING SERVICE
sales@hardchromeplating.co.uk
Steve 07860 235709
Welcome to our new Website
Reliable            Repair            Restore            Renew            Reliance
HARD CHROME PLATING
GRINDING
FORKS RECHROMING
POLISHING
SERVICES
Hard Chrome Plating
Grinding
Polishing
Forks Rechroming
CREATED BY HARD CHROME PLATING & GRINDING 2019
ADDRESS
Unit 15 Hermitage Way
Mansfield
Nottinghamshire
NG18 5ES
/quote]
Re: Bomber fork leg
« Reply #11 on: January 09, 2020, 12:59:33 PM »
Bomber leg arrived this morning in good condition and is easily re-chromeable. So thanks for that, another problem overcome. The stantions were immediately repacked and sent off to Dynasurf in Cheshire for hard chroming. Quoted me £145 including the top nuts plus £12 return postage so not too bad. And they have been recommended by a member on here that has used them recently.
« Last Edit: January 09, 2020, 04:13:05 PM by royhall »
