Author Topic: Gear changing  (Read 1198 times)
Offline brodsord
Gear changing
« on: February 29, 2020, 04:13:46 PM »
Hello everyone,
Could anyone shed some light on why my CB750 k5 engine won’t shift gear with massive pressure on the shift lever when the engine is running?
When the engine is not running the lever shifts through the gears smooth.
I’ve been putting this bike together over last few months, it was just a frame and engine when I got it, engine itself runs great, today is the first day I’ve got her out so I’ve only Just discovered this.
Thanks for any help
Offline brodsord
Re: Gear changing
« Reply #1 on: February 29, 2020, 04:15:08 PM »
Without massive pressure*
Re: Gear changing
« Reply #2 on: February 29, 2020, 04:40:26 PM »
What's the clutch like?
Could be dragging.
Offline brodsord
Re: Gear changing
« Reply #3 on: February 29, 2020, 04:45:54 PM »
Hi John,
There’s a bit of a rattle coming from the clutch area which disappears when lever is pulled in.
When you actually put her into gear the clutch is working correctly from what I can see.
I forgot to mention in post, a few weeks back when I got her first fired up, the drive chain want fitted and she clicked through the gears ok, although there was a bit of noise in forth and fifth gear, sounded like a rattle.
Offline brodsord
Re: Gear changing
« Reply #4 on: February 29, 2020, 04:46:49 PM »
Wasn’t fitted*
F@cking auto correct
Re: Gear changing
« Reply #5 on: February 29, 2020, 04:57:36 PM »
Wasn’t fitted*
I know. Bloody nuisance.
Put it on the stand.rear wheel in the air. With the engine running. Engage all the  gears.
Ideally you sit on it.pull in the clutch. And operate rear brake.
Does the wheel stop ok?
Offline brodsord
Re: Gear changing
« Reply #6 on: February 29, 2020, 05:03:14 PM »
Ahh.
Rear stand arriving next week from America.
I will try that as soon as it’s fitted John
Re: Gear changing
« Reply #7 on: February 29, 2020, 07:03:01 PM »
When you put the drive chain on and the rear wheel is stationary,  then half the gearbox (the half connected to output sprocket)  becomes stationary too.  This generally makes it feel very obstructive so you shouldn't force it. Before that,  no chain, all the gearbox components can revolve together and in effect simulate the bike going along normally.
As John's advice above,  get rear wheel off the ground and try then,  it'll probably feel ok.
I wouldn't force it as described for risk of bending a selector fork.
Offline brodsord
Re: Gear changing
« Reply #8 on: February 29, 2020, 07:10:25 PM »
Thanks K2.
I’ll get back to you both once I’ve got her on the stand.
Thank you both for your advice.
Offline brodsord
Re: Gear changing
« Reply #9 on: April 04, 2020, 02:50:03 PM »
Hi John, hi K2,
Seems I can move through the gears ok,
I can’t seem to get her to go into neutral,
I’ve just rode her around my drive and same thing, changes gear ok but trying to get into neutral is very difficult.
Thanks for any advice.
Graham
Re: Gear changing
« Reply #10 on: April 04, 2020, 04:22:11 PM »
Fairly normal, get used to finding neutral in the last few yards of rolling.
Offline brodsord
Re: Gear changing
« Reply #11 on: April 04, 2020, 04:26:53 PM »
Thanks BryanJ.
It seems that is the norm,
I can cope with that.
Thanks for your reply
Re: Gear changing
« Reply #12 on: April 04, 2020, 04:44:00 PM »
Yes as Bryan says as I approach a junction or traffic lights I get mine in neutral prior to stopping, or stop turn off and find neutral and start up again.
Offline brodsord
Re: Gear changing
« Reply #13 on: April 04, 2020, 04:55:02 PM »
Thanks Dennis,
Did I read something posted from regarding this issue?
Offline brodsord
Re: Gear changing
« Reply #14 on: April 04, 2020, 04:55:36 PM »
Posted from you*
