Author Topic: Refitting carbs But airbox bits missing  (Read 1574 times)
Offline bobv7
« on: March 06, 2020, 05:46:06 PM »
I just refitted the carbs and found the best way fit the intake side to the carbs was to take out the air filter box and battery holder. That leaves a big hole and after much industrial terminolgy and plain brute force I squeezed that into place, (Don't try this if you value the frame paintwork!) but then I've found I'm missing a mounting bracket from the front of the air filter box. I can't find any on line and rather than resort to a couple of cable ties if anyone has one spare and would like to exchange it for some beer tokens please let me know. Ta.
Re: Refitting carbs But airbox bits missing
« Reply #1 on: March 06, 2020, 06:16:16 PM »
Do you have a part number for the part you need Bob?
Offline bobv7
« Reply #2 on: March 06, 2020, 06:30:06 PM »
Hi Julie
I got these numbers off CMS. 17317323010 or 17319323000
I can't be sure which is the right one because it looks like there's a right mishmash of bits lurking under the seat!
OK This is the bit I have
« Reply #3 on: March 06, 2020, 07:35:29 PM »
I have this part for sale on ebay. Part number 17319-323-000
Sent from my I3312 using Tapatalk
Offline bobv7
« Reply #4 on: March 06, 2020, 08:25:26 PM »
Hi Julie
Thanks for the info but the good news is I found it in the shed spiders stash under a stack of flooring boards! ;D Even better news; I've put it all back together again and it actually starts! :D :D :D :D :D. But will it run properly? ::) Time for tea.
« Reply #5 on: March 06, 2020, 08:52:00 PM »
Hi Julie
Great Bob, at least you are sorted.
Offline bobv7
« Reply #6 on: March 08, 2020, 04:08:31 PM »
To continue. Everything is back together and the bike starts but even with all cables and throttle screws off "tick over" 2k+! Could this be throttle slides not seating and/or is the mixture setting wrong? Either way I'm going to need someone with a set of vacuum gauges to sort it. Anyone recommended a service in the Bognor Regis area?
« Reply #7 on: March 08, 2020, 04:24:51 PM »
Did you bench sync the carbs before fitting Bob?
Offline bobv7
« Reply #8 on: March 08, 2020, 05:18:57 PM »
I thought that had been done by the chaps who referbed them for me. I've checked the mixture screws and they are set at one and a half turns out, and operating the throttle by hand they all seemed to be opening together OK. Could it be they're just set to high?
« Reply #9 on: March 08, 2020, 05:51:30 PM »
Yes, either all set too high or 1 or more too high. Did you notice if the slides were fully closing when the idle screw was backed off all the way?
Offline bobv7
« Reply #10 on: March 08, 2020, 07:41:37 PM »
Must have missed that cos' the chokes were closed to stop stuff getting inside...ooops and bugger! Looks like I'm stripping out the air box again. :-[ Any suggestions on what to use to set the right clearances?
« Reply #11 on: March 08, 2020, 07:56:45 PM »
Follow Bryan's guide... Instead of a drill shank, I always use the red squirt tube off of the WD40 can
http://www.sohc.co.uk/index.php/topic,17769.0.html
Offline bobv7
« Reply #12 on: March 08, 2020, 08:14:43 PM »
Cheers Julie
I'll go away now and sulk 'cos I have to do everything all over again. Thanks for your help, much appreciated.
« Reply #13 on: March 08, 2020, 09:50:07 PM »
I can never find one of those squirty straws but trip over drill bits on my desk!!!
« Reply #14 on: March 09, 2020, 06:44:12 AM »
For me a small allen key works fine.
