Author Topic: Clutch adjustment  (Read 447 times)
Offline Dolomite_
Clutch adjustment
« on: March 26, 2020, 06:26:26 PM »
I replaced the clutch plates a few months ago and ive been trying to set the clutch up to my liking but I've had to put the bar end and clutch end bolts really far out to get the clutch to disengage fully. I've tried adjusting the screw and lock nut on the arm mechanism but have only been able to move the biting point about half way from the bar. I know this isnt right.
 Is this a sign that the clutch spring bolts aren't tight enough?
 What is the typical amount each clutch adjustment bolt should be screwed in?
Re: Clutch adjustment
« Reply #1 on: March 26, 2020, 06:33:46 PM »
The spring bolts should be tight.
« Reply #2 on: April 08, 2020, 07:53:04 PM »
Not over tight,  just firm.
