Author Topic: Final reduction gearing  (Read 461 times)
Offline Crispy
« on: March 29, 2020, 02:56:12 PM »
I'm about to try and order new chain and sprockets for my 71 K1, just unsure what to get. The sprockets that I have taken off the bike were 17 & 48 tooth all the technical data suggests 18 & 48 , any advice on what to get? dont want to get the wrong thing and smash my crankcase  :-\
Re: Final reduction gearing
« Reply #1 on: March 29, 2020, 03:22:29 PM »
Is it definitely a K1 motor? Reason I ask, the 750F1 had 17/48 because Honda altered the internal gearing to give closer ratios and quicker acceleration. If it is a K1 motor then somebody has probably done it to make it accelerate quicker or maybe pull a sidecar.
« Reply #2 on: March 29, 2020, 03:25:57 PM »
It was the 16 tooth Honda upgraded because of chain breakage(to 17 tooth)
Offline Green1
« Reply #3 on: March 29, 2020, 03:38:10 PM »
I have 17 and 48 on my K1's.
Saying that I should think 16 will be OK if you don't neglect chain maintenance as modern chains are far better.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Crispy
« Reply #4 on: March 29, 2020, 04:01:48 PM »
Thanks guys, yes it's definitely a K1 motor,  I'll stick with what I've taken off then 17, 48 just wanted to be sure , I knew I had read somewhere that Honda had changed the gearing to prevent chain/case damage just didn't know what from or to !  :)
« Last Edit: March 29, 2020, 04:03:42 PM by Crispy »
