Author Topic: Tank compatibility  (Read 883 times)
Offline jamesw999
Tank compatibility
« on: April 07, 2020, 11:34:12 PM »
Hi All
Does anyone know if a K4 tank will fit on a K6?
CB750
Many thanks
James
Re: Tank compatibility
« Reply #1 on: April 07, 2020, 11:41:05 PM »
Short answer is yes James. Dimensionally identical aside from the fuel tap on K5/6 is on the LHS and has a single outlet to the carbs, whereas the K4 tank will have a RHS dual outlet fuel tap. You can easily reconfigure the fuel feed to the carbs from a single to dual fuel line setup. Hope that helps. James
Offline jamesw999
« Reply #2 on: April 08, 2020, 06:12:21 PM »
Thank you, really helpful  :)
