Author Topic: Broken cam chain guide  (Read 538 times)
Offline Mr Helicop
« on: April 12, 2020, 05:45:53 PM »
Thought the bike was rattling a bit more than usual and on inspection I found the broken cam chain front guide, the adjuster seems to work as it should and I can't see any other problem. Anyone of you guys seen this before? wear and tear or what might have caused it?
Re: Broken cam chain guide
« Reply #1 on: April 12, 2020, 06:06:19 PM »
I think you will find thar the grooves in the cyĺinder are worn (those pins have no rubber left) which has allowed it to rattle up and down thus break.
I have seen it before but not often, could be it was assembled worn by a PO
Offline Mr Helicop
« Reply #2 on: April 12, 2020, 06:23:17 PM »
Yes it was fitted as shown when I serviced the the head - I had no idea that the pins should have rubber on them, I take it the new one should have the rubbers which should cure the problem?
« Reply #3 on: April 12, 2020, 07:14:33 PM »
The rubbers are not seperate but the whole assembly is covered. You need to make sure that the "pins" fit tightly into the machined recesses
Offline Mr Helicop
« Reply #4 on: April 12, 2020, 07:18:43 PM »
Thanks very much for your help, I will see how it fits when it arrives.
