Author Topic: Ignition - or lack of!  (Read 1112 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Ignition - or lack of!
« Reply #15 on: April 17, 2020, 01:15:15 PM »
.... further thoughts. Disconnect the 2 coils (ie the 2 BLACK / WHITES from the Y connector in the previous pic) and see how your battery voltage behaves at IGN ON. (tho’ this ought to be the same as setting the KILL switch to OFF)
« Last Edit: April 17, 2020, 01:17:00 PM by Lobo »
Offline Oggers
« Reply #16 on: April 17, 2020, 01:17:08 PM »
Lobo
Again, many thanks. However, since discussing last, I have charged the battery - to 12.6V, tried it again and it started first kick!
Sounds fine enough, so I presume coils are OK?
Does not explain why the battery discharged so rapidly though, nor the "flash" at the points. Just to confirm, what do you mean by the fibre washers and floating switch ref points insulation. It's a good point and I think worth checking out
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #17 on: April 17, 2020, 04:00:27 PM »
This may not help but when I fitted new points I carelessly re-fitted the (new) condenser tag to the wrong side of the points connection bit so effectively it was just earthed. I realised it needed to be with the coil connection tag within the insulating washer arrangement.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #18 on: April 17, 2020, 10:25:17 PM »
... glad to hear all ok... the easy answers are the best.
When open, the moving side of the points MUST always be electrically isolated from the fixed / grounded side, and this is achieved by specifically placed fibre washers / inserts - depending on the design.
Cheers.
Offline Oggers
« Reply #19 on: April 18, 2020, 05:10:11 PM »
Lobo- Thanks again that is good to know. I have since resorted to my old method of dynamic timing - which is adjust revs to @3000, and move 1.4 contact breaker base plate cw/acw until highest revs obtained. Repeat for 2.3 base plate. I think it will it will suffice until I decide to buy a strobe...
