Author Topic: Clutch slip  (Read 1756 times)
Offline brodsord
Re: Clutch slip
« Reply #15 on: April 28, 2020, 08:05:56 PM »
With a fibre worn that bad i would suggest a full set of fibre and steel.
That plate gets wrecked when the centre outer plate is put on wrong, it only fits in certain places
Thanks Byran,
I’ll probably need to pick your brains if that’s the case when I get the new clutch
Offline brodsord
Re: Clutch slip
« Reply #16 on: April 28, 2020, 08:06:53 PM »
Definitely get a new / replacement clutch lifter plate. Those corners snap off for fun at the best of times. If you can't find a new one to buy, we have loads of good used ones here.
Thanks Julie, I’m going to see if I can get an updated plate as per Phils message below
Re: Clutch slip
« Reply #17 on: April 28, 2020, 10:32:18 PM »
There’s no grooves I meant to add, the plates are smooth, they seem to have a diamond pattern etched in the surface
I think you have misunderstood on what parts to check for grooves. It is the area that I have marked in Yellow.
The double plate was a upgrade on the later 750 engines. Many different clutch baskets and fiber plates on a 750  ;)
Offline brodsord
Re: Clutch slip
« Reply #18 on: April 28, 2020, 10:52:54 PM »
Thanks Trigger,
Yes I’m a bit confused. I will check those in the morning to see if they have grooves in them, if they have will they need to be replaced?
Offline brodsord
Re: Clutch slip
« Reply #19 on: April 29, 2020, 08:57:35 AM »
Morning Trigger,
Those metal areas that you have highlighted in the picture have no grooves at all there completely smooth.
Does that mean there ok?
Offline brodsord
Re: Clutch slip
« Reply #20 on: April 29, 2020, 08:58:03 AM »
Thanks,
Gray
Offline brodsord
Re: Clutch slip
« Reply #21 on: April 29, 2020, 10:40:55 AM »
I’ve taken a few pictures,
The steel plates  that go between the fibre plates, two have small circular almost like punch marks in them, two of them are more flush then there’s a plate that is two plates joined together again this plate is smooth with no punch holes. Are these normal or do they need to be replaced?
Thanks,
Gray
Online Bryanj
Re: Clutch slip
« Reply #22 on: April 29, 2020, 11:03:07 AM »
 The worrying one is the one that has some punch marks but some plain on it which means uneven wear like the one fibre.
The double plate was a mod by Honda to try and stop clutch "rattle"
Due to the abnormal wear personaly i would replace all the fibres and plain steel plates plus the springs, the double plate is probably fine to reuse as its thicker and also discontinued.
It was probably all caused by that broken lifter plate putting uneven tension on the clutch.
Offline brodsord
Re: Clutch slip
« Reply #23 on: April 29, 2020, 11:07:40 AM »
Thanks Bryan, I get those ordered then
Re: Clutch slip
« Reply #24 on: April 29, 2020, 11:40:35 AM »
Looks like someone has been in there before  ;)
Online Bryanj
Re: Clutch slip
« Reply #25 on: April 29, 2020, 12:15:16 PM »
Before you order check how many of each plate you need as it wont be as per parts book due to the mod plate.
If you are getting the lifter plate from Julie might be worth asking her to supply.
Offline brodsord
Re: Clutch slip
« Reply #26 on: April 29, 2020, 12:15:34 PM »
Don’t know wetter it’s a good or a bad thing
Offline brodsord
Re: Clutch slip
« Reply #27 on: April 29, 2020, 12:20:20 PM »
Thanks Bryan, I didn’t realise Julie sold all parts I’ll message now for cost
Online Bryanj
Re: Clutch slip
« Reply #28 on: April 29, 2020, 02:27:59 PM »
The number of 750's Trigger builds i would be surprised if they didnt have any!
Offline brodsord
Re: Clutch slip
« Reply #29 on: April 29, 2020, 02:43:25 PM »
Good to know thanks Bryan
