Author Topic: Gearbox Coutershaft  (Read 390 times)
Offline BrianC500
  • Restoring to get back on 2 wheels
Gearbox Coutershaft
« on: April 28, 2020, 02:43:24 PM »
Hi,
I'm currently starting the rebuild of a 1975 model. While stripping and cleaning the coutershaft assembly I've hit a problem. I need to replace both the ball and needle bearings. The grooved twin row bearing is held in position by a sleeve. Will a normal 3 legged bearing puller pull this off? Pic is attached.
Thanks in advance
Previous bikes CB175K6, GS550EZ, GL1100
Re: Gearbox Coutershaft
« Reply #1 on: April 28, 2020, 03:05:40 PM »
Not if pull on the gear
Offline BrianC500
« Reply #2 on: April 28, 2020, 03:23:38 PM »
Would it be better if it was pressed out? Unfortunately I do need to replace the bearing as it is very growly.
