Author Topic: CB750 K1  (Read 727 times)
Offline 750rideruk
CB750 K1
« on: April 28, 2020, 07:02:43 PM »
When cruising at about 60-70 my bike seems to 'hunt' or falter slightly. Opening the throttle it is fine. As we are only part throttle I have ordered pilot jets size 42 which is one size up. these are about 4 mm longer than the STD ones. will these be OK as obviously will pick up fuel from lower in the float bowl.. Can anyone throw any light on my predicament?
Re: CB750 K1
« Reply #1 on: April 28, 2020, 07:17:42 PM »
It's more likely the needle
Try lifting the clip one slot.
Making it slightly leaner.
What colour are the plugs?
Offline Arch stanton
Re: CB750 K1
« Reply #2 on: April 30, 2020, 07:36:41 AM »
You don't mention other important factors.
Exhaust or airfilter/pods or standard.
But I found recently. Upping the pilots won't help.
My 750k1 has 4 into 1 and Bellmouths.
After a lot of farting about. It now runs pretty damn good
Through the range.
Standard pilots. Needles up 1 notch. 120 mains.
Offline 750rideruk
Re: CB750 K1
« Reply #3 on: April 30, 2020, 02:31:02 PM »
its got std airfilter and 341 exhausts. I thought that the bike might be running a bit weak as it feels as if it needs more fuel as when opening the throttle from cruising it pulls strongly.
Offline mick
Re: CB750 K1
« Reply #4 on: April 30, 2020, 09:35:02 PM »
this may be of some help to you ?
