Author Topic: 550k3 front indicator stems  (Read 927 times)
Offline 3scs
« on: May 05, 2020, 08:55:06 PM »
Does anyone have a pair of front indicator stems for sale I think the part number is 90154-404-610 think they are the same ones as 750 f2 ones thread size is m14x 1.50 also looking for a 550 k3 grab rail
Offline 3scs
Re: 550k3 front indicator stems
« Reply #1 on: May 05, 2020, 09:43:23 PM »
Are we talking about the large type indicators or the more normal UK type.
I know the K3 had the big indicators but you may be converting to the UK type.
so what are the correct indicators for the uk k3 my k3 has f1 forks and ears fitted I’m trying to make it the right spec for the uk model
Offline 3scs
« Reply #2 on: May 08, 2020, 08:23:13 AM »
What's wrong with the stems on the pic?
Oh and are the stems male or female, in that some screw onto a threaded boss on the ear and some screw into the ear.
K3 indicators are the same type as you've already got fitted, bloody great big things.
nothing wrong with the ones fitted apart from they are 550f1 ones I have a pair of k3 ears with no stems and yes your right the f1 stems are female thread and the k3 ones are male
Offline mickwinf
« Reply #3 on: May 08, 2020, 09:19:21 AM »
the indicators and stems look correct for the k3, but the ears are f1 items as they have the fitting for fork gaiters. The k3 and f2 did not have the gaiters and part number for the ears is the same (k3 and f2) yet the k3 used the big indicators and the f2 used the small ones so the stems are different
Offline 3scs
« Reply #4 on: May 08, 2020, 10:01:22 AM »
hi Mick the indicators are near enough correct they are USA ones as they have twin filament bulbs in them the stems look the same as k3 but where they mount to the ears they have female thread instead of male the forks are f1 but I’ve got some f2/k3 ones just need to go to philpotts for straightening and chroming but getting there slowly
Offline mickwinf
« Reply #5 on: May 08, 2020, 10:54:28 AM »
ah yes i think the US ones were different and had a threaded piece sticking off the ear. I may be able to supply you with the correct items will check later
Offline mickwinf
« Reply #6 on: May 08, 2020, 11:23:43 AM »
Simon these are the ones i have, also have a selection of indicators and single wire fittings if you need them
Offline 3scs
« Reply #7 on: May 08, 2020, 11:38:42 AM »
They look like the ones are they 14mm thread if so put my name on them and when we’re released I will give you a call if that’s ok
Offline mickwinf
« Reply #8 on: May 08, 2020, 07:16:24 PM »
oddjob, not sure at the moment as was going to have them rechromed at a later date, but selling the f2 due to finances going downhill. Not even sure if i will get another bike in the near future.
