Author Topic: Front fork lengths  (Read 466 times)
Offline Rjgordon0
Front fork lengths
« on: May 06, 2020, 07:37:25 PM »
Hi all, just bought two 1977 & 1978 CB750F2 supersports & have been renovating them. The 78' came in bits, the frame etc already painted & ready to build. The 78' is a complete non running shed of a bike. Just finished reassembling the 77' forks & realised they are approximately 30mm longer than the 78' forks. Upon a strip down the 77' fork stanchion pipes are longer than the 78's !! Does anyone know why as they are meant to be the same bike ?
Re: Front fork lengths
« Reply #1 on: May 06, 2020, 08:16:26 PM »
In 40+ years they could be from a different Honda due to accident damage/rusty stanchions etc and someone fitted whatever was available bat the right money.
« Reply #2 on: May 06, 2020, 09:16:50 PM »
Somebody fitted 3 inch overs for a chopper look?
Are the springs the same length with a spacer?
« Reply #3 on: May 06, 2020, 10:34:25 PM »
30mm is barely over an inch Bryan  (bloody foreign metric measurements!)
Offline Rjgordon0
« Reply #4 on: May 06, 2020, 10:53:51 PM »
Hi, the spring lengths are the same & so are the fork slider bottoms. The inner damper rod that is fixed to the bottom slider via machined hole at the base & a socket screw is approx 30mm longer as well. I guess I would need to find out from Honda the correct lengths per item for model & year. The suggestion that they came of another bike due to the age is perfectly feasible. I could leave it for the time being & see how the bike sits when finished !!!
Thanks for the replies 😎
