Author Topic: Negative or Ground  (Read 554 times)
Offline legin101
Negative or Ground
« on: May 25, 2020, 11:25:40 AM »
Hi all i am reasonably ok with electrics and have a good idea how it works but i have a slight problem ive never come across before with the F2 its got a negative (Black) and a ground(Green) which ultimately go to the neg terminal of the battery. what is the difference and why.
nigel
nigel
GT750L 1974
gsx750ET 1980
CB750F2 1979
MT10 2017
Re: Negative or Ground
« Reply #1 on: May 25, 2020, 11:33:29 AM »
Ground and earth are two terms for the same thing. All Honda loom earths are green but the heavy duty negative lead is black and positive red
« Reply #2 on: May 25, 2020, 01:26:32 PM »
And then the positive turns black 😃
Until you know what's what, best use a circuit diagram
« Reply #3 on: May 25, 2020, 02:10:58 PM »
Only turns black after its swiched on
« Reply #4 on: June 06, 2020, 11:00:11 PM »
If you connect it to the mains  it'll all turn black.
