Author Topic: earthing the wire loom. cb550k3  (Read 460 times)
Offline nairb
« on: May 30, 2020, 03:49:32 PM »
Its ages ago i started the re-build for the 550.  In fact I have built a couple of other bikes since.....  So its the same old story - many years after the re-build started I finally returned to finish it.  The frame & bits have all been powder coated etc so its been well apart and now nearly all back together again.  Almost.
There is a earth strap from the engine to the battery.  Which is good.  But was there an earth strap from the engine to frame and/or a earth point on the wiring loom.  The wiring diagram shows a earth point.  So I need to earth it somewhere.  I cannot find an earthing wire from the loom.  Was it a bullet connector and wire to frame.
Digital cameras make re-builds much easier nowadays.  Back in 1995 when I started to fix the 550 the cameras were a bit pricey.
Ta
Nairb
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2,  gt380 Kz750 twin cb360K0
Offline SteveW
Re: earthing the wire loom. cb550k3
« Reply #1 on: May 30, 2020, 04:04:55 PM »
Mine is a 550 K0 and the green earth wire is earthed to the left hand side bolt that holds the coil to the frame.
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline nairb
« Reply #2 on: May 30, 2020, 04:56:21 PM »
Just checked and so is mine as well.  Thanks.  Thick green wire.  I had looked on the electrical panel on the LHS.  Wrong place
The indicators are slow to turn over so I thought it might be an earthing issue.
I will run an earth wire from the battery -ve terminal to the frame also.  Then there cannot be any doubt
Ta
Nairb
