Author Topic: Where are these D washers from?  (Read 1411 times)
Offline Andrew-S
« on: June 01, 2020, 11:42:04 AM »
Just refitting the brake caliper adjuster spring and found two D washers in the same bag, it seems there's a 6mm plain washer missing but wondered where these D washers are from?
Thanks,
Andrew
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline Phil k
Re: Where are these D washers from?
« Reply #1 on: June 01, 2020, 11:45:45 AM »
Could be calliper spacers, but look like the washers from the triple tee clamp
Honda CB750 K5
2004 BMW R1100s
Honda CRF250X
Honda CRF230F
Offline Andrew-S
« Reply #2 on: June 01, 2020, 12:21:34 PM »
Thanks Phil, spot on!
Cheers,
Andrew
1976 UK Z900 A4
2018 BMW R1200 GS
Offline bhudders
« Reply #3 on: June 01, 2020, 12:42:01 PM »
Triple tree clamp
Offline Andrew-S
« Reply #4 on: June 01, 2020, 01:05:55 PM »
Triple tree clamp
Yes, forgot to mention that in my 'excitement' above....... ::)  ;D
1976 UK Z900 A4
2018 BMW R1200 GS
« Reply #5 on: June 01, 2020, 01:11:53 PM »
Bloody yanks ! Its a Top Yoke!!!
Offline Phil k
« Reply #6 on: June 01, 2020, 01:30:47 PM »
I know it’s a yoke, but it’s also a triple tee in parts of the world :)
And Please don’t call me a septic 🙏
Honda CB750 K5
2004 BMW R1100s
Honda CRF250X
Honda CRF230F
« Reply #7 on: June 01, 2020, 05:02:52 PM »
I see you are from the North East, spent several years in Southshields where they put a zebra crossing about 5 yards from every roundabout exit.
Would never call you septic. Its as somebody famous said "the UK and the US are two countries separated by the same language"
Offline Phil k
« Reply #8 on: June 01, 2020, 07:16:06 PM »
The crossings are just a test to see if drivers are awake 😳
No worries
Phil 👍
Honda CB750 K5
2004 BMW R1100s
Honda CRF250X
Honda CRF230F
Offline Moorey
« Reply #9 on: June 01, 2020, 08:07:46 PM »
Yet supposedly based from England.
Why is it called a triple tree?
The Triple Tree was the name referred to the typical structure of Tyburn gallows, composed by a beam placed across the branches of two trees. The triangle shape of this structure provided it the name of the Triple Tree, used the first time in 1571, at the time of the execution of the Catholic cleric John Story.
Offline Andrew-S
« Reply #10 on: June 01, 2020, 09:54:24 PM »
I've known it as a 'triple clamp' since the early 70s..........just saying.  ;D
1976 UK Z900 A4
2018 BMW R1200 GS
Offline robvangulik
  • Honda Fourever
« Reply #11 on: June 02, 2020, 11:03:05 PM »
Over here it's called the "bovenste en onderste kroonplaat" and i bet none of you can even pronounce that right ;)
« Reply #12 on: June 03, 2020, 06:51:58 AM »
I will have you know i speak perfect gibberish!!
« Reply #13 on: June 03, 2020, 10:09:48 AM »
Mr Google says that means “most beautiful and lower crown plate”
2022 Tiger Sport 660
Offline Andrew-S
« Reply #14 on: June 03, 2020, 11:24:46 AM »
Nearly there, but to me in my best Neder lingo it's the 'bovenste  kroonplaat'.............or top triple clamp if you like?  ;D
1976 UK Z900 A4
2018 BMW R1200 GS
