Author Topic: flooding carbs  (Read 990 times)
Offline RGP750
flooding carbs
« on: June 05, 2020, 07:31:44 PM »
Hi strangers not been here for a while .
Almost have the gold 500 back on the road (yours Steve)
carbs totally stripped and ultrasonically cleaned put back together with new float jets and housings. and seals
floats set at 22mm bench tested for leaks and two ctr overflowing . Tried just tapping float bowls ,still leaking .
Took bowels off and result one of the overflow tubes is leaking . all floats are free.
Change for another float bowl
now they are all overflowing Grrrrrr! any thoughts please
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: flooding carbs
« Reply #1 on: June 05, 2020, 07:34:56 PM »
I was beginning to wonder what had happened to you Rich!
FWIW, I could never get them to stop leaking either.
2022 Tiger Sport 660
Offline RGP750
Re: flooding carbs
« Reply #2 on: June 05, 2020, 07:46:32 PM »
Hope to have it on the Road next week Steve,
There was only one leaking when I got it from you and I recon that was the one with the split tube .
Hope I can sort it with one help on here.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Re: flooding carbs
« Reply #3 on: June 05, 2020, 08:02:24 PM »
Check the seat area that the taper valve closes onto.  If you've changed them they can have tool chatter from machining operation. Look with magnifier to see what they're like.
A wooden dowel sharpened to a taper,  fine cut grinding paste,  put dowel in vice and spin brass valve in drill chuck to clean the finish in there.
Offline RGP750
Re: flooding carbs
« Reply #4 on: June 05, 2020, 08:44:52 PM »
Thanks guys
Thats tomorrows next stinky job then .
I'll report tomorrow night ,fingers crossed
1973 CB175
1972 CB175
1969 750 K0
Offline Woodside
Re: flooding carbs
« Reply #5 on: June 05, 2020, 09:08:34 PM »
Good luck rich.
Has anyone heard from gerban recently.
I've sent a few emails recently about various things  with no reply .?
Offline RGP750
Re: flooding carbs
« Reply #6 on: June 06, 2020, 06:28:30 PM »
Up date
Did the reseating excersise and just the odd drip every 5 mins
from 2 and 3 but every now and then no 2 drops about a thimble full and then stops. Weird!!
Blasted round float bowl 'o' rings get 5mm longer when they get petrol on them had to hang them in the sun for an hour to shrink back .
4 of the bowl screws also needed tapping out to 5mm, thought I might get away with it yesterday but after a nights sleep thought I need to do it properly .
Plan to have another go at 2 and 3 again tomorrow so hopefully nearly there.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Re: flooding carbs
« Reply #7 on: June 06, 2020, 06:33:54 PM »
Up date
Can I offer to sell you a full Viton carb O ring kit Rich, it will save you having to hang your bits out to dry in the future 🤣🤣🤣🤣
Offline RGP750
Re: flooding carbs
« Reply #8 on: June 06, 2020, 06:47:20 PM »
you could have said that when you sent the screws ::) ;D
How quick can you get them to me then?
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Re: flooding carbs
« Reply #9 on: June 06, 2020, 06:49:36 PM »
I have the kits in stock, can post 1st class Monday and if Royal Mail do their job, you will have them Tuesday.
« Last Edit: June 06, 2020, 06:52:44 PM by Nurse Julie »
Offline RGP750
Re: flooding carbs
« Reply #10 on: June 06, 2020, 07:13:57 PM »
can you do just the float bowl ones? ,don't really want to take the whole things to bits again :-\
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline mattsz
Re: flooding carbs
« Reply #11 on: June 17, 2020, 01:22:14 AM »
I used to test mine by connecting a fuel source up to the fuel pipe and holding the float jet up into the seat with my finger, if fuel got past then I'd replace or repair the jet/seat. I'd then reinstall the float and hold it up with my finger and see if it leaked then. Checking them on a bench with fuel is far better then hoping they'll not leak on the bike, it's messy, it stinks but it works for me. I'd lift the float up until it just touched the sprung pin, if it stopped the fuel flow then I'd be confident it would do so when installed on the bike.
Can the float valves be effectively bench-tested this way using something less stinky than actual fuel?  Maybe mineral spirits, or even better, alcohol?
