Author Topic: Oil and cylinder pressures  (Read 345 times)
Offline Chris whit
« on: June 06, 2020, 07:45:36 PM »
Hi Guys , could anyone let me know the cylinder compression and oil pressure PSI for a 550F2 . Just rebuilt the engine and i am just about to test the pressures before i fit back into the frame .
Re: Oil and cylinder pressures
« Reply #1 on: June 06, 2020, 08:39:46 PM »
Both should be in manual but if light goes out oil is ok and you wont get full compression till after its been run and is warm
