Author Topic: Loom routing  (Read 380 times)
Offline paulbaker1954
Loom routing
« on: June 11, 2020, 12:50:52 PM »
My main loom to the headlight shell runs on the left of the frame above the tank front locating rubbers as in the picture. I have noticed that the routing causes the loom to flex when turning the bars lock to lock.
I am concerned this flexing will eventually damage the loom wiring and was just wondering if this is the correct routing?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Loom routing
« Reply #1 on: June 11, 2020, 01:53:44 PM »
Under the tank rubber, there should be a clip that goes on before the rubber that, the loom hangs in  ;)
Like so
« Last Edit: June 11, 2020, 01:56:59 PM by Trigger »
