Author Topic: Removing engine to frame bracket  (Read 561 times)
Offline Athame57
    • SeaWitch Artist
« on: June 16, 2020, 03:38:31 PM »
I wanted to adjust the cam chain tensioner today but found that I could not remove the brackets that are on either side of the tensioner bolts. The two forward ones weren't a problem but the large one at the engine end is inaccessible with any spanner I have due to room between bolt and engine, does this job need a special tool or something?
1978 CB400F2 called Elen.
Re: Removing engine to frame bracket
« Reply #1 on: June 16, 2020, 05:36:13 PM »
Normal 6 sided 3/8 drive socket should fit ok but why remove plate to adjust chain
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: June 16, 2020, 05:57:40 PM »
I can't see how to access the bolt without moving the plates.
« Reply #3 on: June 16, 2020, 06:04:21 PM »
Have you got crash bars fitted?
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: June 16, 2020, 06:42:33 PM »
No...
« Reply #5 on: June 16, 2020, 08:13:18 PM »
Never removed plates in normal service operations, just used sockets and spanners
« Reply #6 on: June 16, 2020, 10:38:41 PM »
You're not trying to remove the blanking plug instead are you?
Offline Athame57
    • SeaWitch Artist
« Reply #7 on: June 16, 2020, 10:51:37 PM »
Just put 'cb400f cam blanking plug' into google images. I see the adjuster bolt  goes into a plug that goes into engine. hhmmm...mine has a hole for an allen key in it...looks like I've got another bodge to get rid of. some previous owner left me with a home made brake arm and non standard clutch cable with wrong fittings to sort out as well. .... I think I want the plates off so I can have a good look....
« Reply #8 on: June 17, 2020, 08:22:19 AM »
OK its not an adjuster bolt its a locking bolt to stop the internal adjust bar moving.
The original bolt had a 6mm thread that screwed direct into the alloy crankcase with an 8mm thread just under the head for the locking nut. I have linked to a stainless repair kit on the forum already somewhere.
