Author Topic: Air filter box gasket  (Read 548 times)
Offline Moorey
« on: June 19, 2020, 09:29:13 PM »
  The gasket on the 705F1 air filter box seperator has got big and baggy and it would seem you can't buy just the gasket. It is a square C section in shape. Open to suggestions as i am struggling to find anything suitable.
Or if anyone has a good 750f1 airbox / gasket they don't want as mine seems to have got a little out of shape.
Re: Air filter box gasket
« Reply #1 on: June 19, 2020, 10:10:08 PM »
I tried to find some for one of our CB 750 Air boxes Chris, without any luck. In the end I had to cut down the original, which like yours had gone saggy, and then superglue the ends together again. It worked a treat.
When I was darn sarf in my home town for a few days (last year) I went to a specialist company that I used to deal with to see if they did anything close enough but, what they made was just not close enough.
https://coh-baines.co.uk/
« Last Edit: June 19, 2020, 10:13:04 PM by Nurse Julie »
Offline Moorey
« Reply #2 on: June 19, 2020, 10:24:17 PM »
Cheers Julie just trawlin tinternet i might have found a stockist i need to measure up for a suitable fit to see if they have anything near the right size but it does look promising. At least i know what cross section to search for now.  ;D
If it comes down to it i will just cut out the excess and glue.
« Reply #3 on: June 19, 2020, 10:28:04 PM »
That sounds hopeful Chris. Baines had one that was quite close but not close enough for Trig, that's why I ended up doing a bit of cutting and shutting on our 😊😊😊
