Author Topic: My CB550 K3 Restore Project  (Read 13815 times)
Offline heli_madken
Re: My CB550 K3 Restore Project
« Reply #60 on: September 25, 2020, 05:33:15 PM »
Had an enjoyable day putting the cases back together.
I have replaced all the oil seals. Most difficult one was the alternator only because I had a screw up with Fedex ordering an M16/1.5 x 50mm bolt (I am sorry COVID is no longer an excuse for a package to take days when you have paid next day delivery, TAKE ON MORE STAFF!! and stop using the situation to increase your profits) sorry rant over. Once I got the bolt my impact wrench made very short work of the rotor.
Also replaced main shaft bearings which where surprisingly easy to do, it helped a lot putting the shaft in the freezer overnight.
I nearly didnt replace the primary rubber's after forgetting to order them but I am glad I did now, the originals are rock hard compared to the new ones -
Everything placed in position, all gears select nicely and everything runs smooth, I used a smear of Threebond to seal the cases -
Cases went back together easy and everything torqued up nicely followed by driving in the main shaft -
The difference in the tightness of the primary drive chain is staggering, when I compared new to old I was a little perturbed that there wasn't that much difference but wow once in place it really is much tighter.
I plan on getting the engine back in the frame and built up completely over the next few days.
« Reply #61 on: September 25, 2020, 05:49:44 PM »
It is always a false economy not replacing the primary rubbers, the chain wears out in half the time.
Coming together nicely  ;)
Offline heli_madken
« Reply #62 on: September 27, 2020, 06:29:51 PM »
Thanks Trigger I am glad I waited for them to arrive.
Pistons and cylinder block back on, used new rings and gudgeon clips.
Then got the engine back in the frame whilst it is still relatively light, did the frame over the engine thing which worked really well and I didn't scratch the frame!
One of those bottles of Yellow Tail has my name on it tonight!
Using all new nice shiny fixings -
Finish off cylinder head next and get the rest of the engine assembled
« Reply #63 on: September 27, 2020, 09:26:35 PM »
(Attachment Link)
(Attachment Link)
Wow that's a "better than new" looking engine in your photos - very nice.
Offline heli_madken
« Reply #64 on: September 30, 2020, 05:57:35 PM »
Moving along nicely, rebuilt the head with a light lapping and a good clean on the valves which were thick with crud, fitted new stem seals etc.
Fitted the head and torqued up all the bolts then put the camshaft and sprocket in place being careful with positioning, set timing at 15' ATDC.
Re-assembled the rocker cover and bolted in place after backing off all the adjusters then did an initial clearance check. Did a few revolutions just to check everything moved freely. Also fitted the oil strainer and sump.
So this is where I am at -
Tomorrow I am going to fit the alternator, starter motor and clutch so the engine will be back together.
« Reply #65 on: October 01, 2020, 12:00:25 PM »
Looking fantastic.  What are you going to use for a shaving mirror now that you've fitted the rocker cover :D
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline heli_madken
« Reply #66 on: October 01, 2020, 11:22:34 PM »
Shaving is ok but I have had to declare it to my insurance company as a possible threat to other road users due to the blinding effect of the sun or driving lights. Reminds me of my mates Lambretta in the 70's it had so many mirrors if you caught the sun at a certain angle your retina's were scorched beyond repair.
Seriously I know this isn't to everyone's taste and it certainly isn't I guess a 'restore' in the truest sense but considering how the bike looked before I think its a great improvement. I am not seeking 'originality' just to make a nice 1970's look and feel bike that is reliable and fun to ride without the trendy cafe racer look.
Finished up the core components of the engine today, I absolutely love the shape of Japanese engines from this period -
Unfortunately that is it for a while, I have a whole house to decorate and spruce up ready for selling in the new year and moving on now that the kids have moved out, would love to get her finished but needs must.
Offline heli_madken
« Reply #67 on: November 15, 2020, 05:26:15 PM »
Got fed up of painting, decorating, tiling, floor refinishing, plumbing, electrics etc so decided to do some more on the 550 -
I serviced the carbs a while back so just polished the tops and float bowls and got them fitted. What a job it is getting them in place but managed without scratching any of the newly painted stuff -
Got the airbox painted and fitted the intake duct came up well -
Battery box painted and fitted -
Rear swing arm in place together with some nice new TEC shocks which are excellent value for money, thanks to this forum for pointing them out. Also fitted the main stand and new spring, found it easier to fit the spring first then drive in the pivot pin -
Next up is to think about getting her on wheels. I intend to buy new rims and spokes and have a go at lacing myself after reading all the post on the subject, not something I have done before so it will be a challenge.
Offline smoothoperator
« Reply #68 on: November 21, 2020, 06:47:08 PM »
I'm very much in awe of your rebuild and the standard of finish is stunning. Can I ask please what paints you used for your frame?
Steve
2017 Triumph Bonneville T100
Offline ST1100
« Reply #69 on: November 21, 2020, 07:25:49 PM »
@heli_madken
looking awsome... keep going  8)
STOC #637
Offline heli_madken
« Reply #70 on: November 22, 2020, 12:17:44 AM »
Thanks for your comment. The paint is by a company called Jawel - https://www.jawel.co.uk/ I use their 2K super black gloss which goes on really nice and flats out wonderfully so no need for any further polishing. It is a 2K paint though so air fed mask is essential. It is quite flexible, doesnt chip easily and is very durable.
Their 2K primer is also very nice to use but does need to be scuffed before applying the black, for this I use Farecla G-Scuff which is perfect for working on a frame
Offline heli_madken
« Reply #71 on: November 27, 2020, 03:12:38 PM »
My next target is to get the bike on its wheels so I have started ordering bits and getting everything apart, cleaned and ready.
The existing rims are DID and I had hoped to rescue them, the surfaces where badly scratched from tyre iron use and very heavily corroded but I had considered getting them chromed. However when I took the tyres off the PO had used half a roll of duct tape instead of rim tape and as a result water had collected inside the wheel underneath the tape and both rims where almost rusted through. So I have new rims and spokes on order from Central wheel. You can see how bad the front wheel is in the photo below -
With the spokes removed I could remove the old bearings and do my usual polishing. The retainer was well and truly corroded into place but I was able to get it out by drilling a couple of holes and prying it out with an old wood chisel - The hub was very badly pitted but I was able to get it presentable with the use of wet and dry and lots of elbow grease. Pleased to have got it to this stage from what it was in the picture above. I can fit the new bearings and seal now -
The rear hub is also going to be a challenge! -
The headlamp ears have me perplexed, both are very badly corroded -
I can get them presentable with some very heavy polishing -
But the back is a dead loss. Both of them have some damage which you can see towards the headlamp mount which will be very difficult to repair due to the double skin nature of the parts so I am a bit reluctant to get them chromed.
Looked for a while for some replacements in better condition but so far no luck, CMS have one side new but there isnt much point buying just one especially for the price.
I guess I could polish the fronts and spray the inner side with something, perhaps silver or try to find a decent chrome spray, any ideas?
Offline Kelly E
  • Geriatric Hooligan
« Reply #72 on: November 27, 2020, 03:40:44 PM »
Soak those rusted parts in EvapoRust. I have used it on worse stuff than that and they came out rust free. Then polish and wax to keep the rust from coming back.
The Rust Brothers Garage Collection
1974 Honda CB550 K0
1975 Honda CB400F Super Sport
1979 Honda CB750F Super Sport
1980 Suzuki GS1100E
1982 Honda CB900F Super Sport
1983 Honda CB1100F
1984 Honda VF700S Sabre
1984 Honda VF1000F Interceptor
1990 Moto Guzzi 1000 Le Mans
1994 Kawasaki Concours ZG1000
2006 Harley Davidson Fat Boy
« Reply #73 on: November 27, 2020, 04:16:34 PM »
Could you not get them brazed up and then polish the braze before chroming.
Would be very difficult to see that position when they were fitted.
Regards,
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Online Bryanj
« Reply #74 on: November 27, 2020, 04:58:38 PM »
That is less than normal corrosion in that place
