Author Topic: DSS Wiring loom  (Read 941 times)
Offline bomber
DSS Wiring loom
« on: June 24, 2020, 10:59:51 PM »
Hello Everyone!
Gosh It's been few years since I last worked on my Honda.
Finally decided to do a bit of a push, on electrics now...
So I got a ready made loom from DSS unfortunately since wiring on my bike has been badly butchered I'm struggling with working out what color goes where as they obviously don't match...
I wonder if anyone of you folks have a similar experience and could advice...
Also, to my untrained eye, all the wires have same thickness and I wonder should it be like this?
I have read here :) that headlight's should be thicker cable, I'm planning to go for a H4 upgrade and not sure if that's good idea.
Many thanks
G
One step forward, two steps backward...
Honda CB550F 1976
Re: DSS Wiring loom
« Reply #1 on: June 24, 2020, 11:08:37 PM »
I've used DS wiring harness' on all 3 750's I've rebuilt with no issues
Re: DSS Wiring loom
« Reply #2 on: June 25, 2020, 06:32:37 AM »
If its a 500/550 dont go standard H4 the generator isnt man enough unless you keep the revs high.
I have heard of lower wattage H4 but not had one on my hands
Re: DSS Wiring loom
« Reply #3 on: June 25, 2020, 01:34:59 PM »
Try Paul Goff @  http://www.norbsa02.freeuk.com/
He does a range of really bright LED headlamp bulbs suitable for our old clunkers. Paul always attends the Kempton Park Autojumble so a good excuse to pay a visit to one of the best autojumbles in the UK.
I'm going to get a full set of LED lamps for my Triton from Paul if I ever get the chrome back to finish it!
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline bomber
Re: DSS Wiring loom
« Reply #4 on: June 26, 2020, 01:42:06 PM »
Thanks Dave
Sounds interesting however I will stick to standard low power H4, as soon as i get the wiring sorted...
 ;D
Honda CB550F 1976
Offline bomber
Re: DSS Wiring loom
« Reply #5 on: June 26, 2020, 01:43:35 PM »
Thanks Bryanj!
That's the plan read about the lower wattage, will give it a go, eventually...
Honda CB550F 1976
Offline bomber
Re: DSS Wiring loom
« Reply #6 on: June 26, 2020, 01:45:54 PM »
Phil, no doubt you have tons of experience!
For folks like myself without any reference points a part of badly messed up old harness it is rather tricky  ;)
Honda CB550F 1976
Offline bomber
Re: DSS Wiring loom
« Reply #7 on: June 26, 2020, 01:48:09 PM »
I wonder if any one with new DSS harness has pictures of the connections in the lamp head?
That would be most helpful.
G
Honda CB550F 1976
Re: DSS Wiring loom
« Reply #8 on: June 26, 2020, 05:03:47 PM »
G
I'm affraid I don't want to disturb the rats nest of wires in my headlight (you could not make any sense of the wires in a picture anyway as there is so many crammed into a tight space) but I have had no trouble matching the colours in the loom to the associated wires on switches etc. I got this from the forum (or US forum) some time ago that may help
Honda – 1970’s Wiring
Main Color/Tracer Stripe Color- Description (Approximate Path, if Applicable)
All Circuits
Red- Constant Hot From Battery (Battery Terminal-Main Fuse-Key Switch)
Black- Switched Power Supply Buss (Throughout motorcycle)
Green- Ground (Throughout motorcycle)
Lighting
Brown- Tail Light Power (Main Switch-Tail Light)
Brown/White- Instrumentation Backlighting (Lighting Switch-Instruments)
Orange- Left Turn Signals (Turn Signal Switch-Front/Rear Signals)
Orange/White- Left Front Marker (Light Switch-Marker Lamp)
Light Blue- Right Turn Signals (Turn Signal Switch-Front/Rear Signals)
Light Blue/White- Right Front Marker (Light Switch-Marker Lamp)
Gray- Pulsing Power for Signals (Flasher Relay-Turn Signal Switch)
Blue- High Beam Power (Hi/Lo Switch-Headlamp/Indicator Lamp)
White- Low Beam Power (Hi/Lo Switch-Headlamp)
Brown/Red- Fused Headlamp Power (Fuse Box-Hi/Lo Switch)
Ignition
Black/White- Coil Power Supply (Cutoff Switch-Coils)
Yellow- Breaker Signal, Cylinders 2&3 (Right Points-2&3 Coil)
Blue- Breaker Signal, Cylinders 1&4 (Left Points-1&4 Coil)
Starting/Safety/Monitoring
Blue/Red- Oil Pressure Signal (Oil Pressure Switch-Indicator Lamp)
Red/Green- Neutral Switch Signal (Neutral Switch-Indicator Lamp-Safety Unit)
Green/Red- Clutch Switch (Safety Unit-Clutch Switch-Starter Button)
Green/White- Horn (Horn Button-Horn)
Yellow/Red- Solenoid Signal (Starter Button-Solenoid/Safety Unit)
Green/Yellow- Brake Light Power (Front Brake Switch/Rear Brake Switch-Brake Light)
Brown/Blue- Turn Signal Pickup (Turn Signal Beeper-Turn Signal Switch)
Charging (3-Phase External Excitation Systems)
Yellow- Stator Coil Output (Stator-Rectifier)
White- Field Coil Supply (Field Coil-Voltage Regulator)
Red/White- Positive Rectifier Output (Rectifier-Battery)
**NOTE- I pieced this together from referring to wiring diagrams I have. This is meant as a general guide and will vary between models/years. If anyone spots an error or omission, please post it and I will correct it. Thanks**
Offline bomber
Re: DSS Wiring loom
« Reply #9 on: June 30, 2020, 09:56:13 PM »
Thank you Phil!
Very helpful, actually i'm getting closer to working out what is wrong with DSS harness.
Honda CB550F 1976
