Author Topic: Cb550k3 Rectifier  (Read 2067 times)
Re: Cb550k3 Rectifier
« Reply #15 on: July 05, 2020, 08:57:23 AM »
Mine was the standard Honda item.  The difference between the OEM one and what you've got is, maybe,  the heatsink.   Yours might run a bit too hot and break down.  You can always add a heatsink to it if you think it's inadequate.  With a smidge of heatsink paste.
« Reply #16 on: July 05, 2020, 11:42:44 AM »
Thanks for that I did wonder about the heat side of it. I will keep an eye on it after a couple of longer runs, I will probably replace at some point with the correct item in keeping with the bike spec. (he says with his electronic ignition)🤫
1978 Honda CB550K3.
Offline nairb
« Reply #17 on: July 05, 2020, 05:04:51 PM »
I made up several sets of replacement rectifiers years ago expecting them to fail..... Some with heatsinks and others without.  Not one has failed.  Not had a battery go flat either.
Another useful thing from fleabay was a small digital readout.  I put some long wires on and clipped it to the handlbars to check the charging voltage.  Nice to see for a few days. All worked as it should with the new setup.  They seem to be reliable
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2,  gt380 Kz750 twin cb360K0
« Reply #18 on: July 05, 2020, 06:47:23 PM »
That’s interesting to know. Had my first run out with bike this afternoon, checked rectifier on return and only slightly warm. Funny thing I was wishing I had a volt gauge on the bike to keep an eye on charging.
1978 Honda CB550K3.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #19 on: July 05, 2020, 07:41:21 PM »
Hi Johnny,
I had the same problem of wanting to know battery voltage on our MX-5 - the ECU does the regulating and they seem to charge at or near 15volts, which I am a bit uneasy with.  Anyway, I bought a couple of very cheap voltage displays and fastened one to a cigar lighter plug to do some checking.  You could easily adapt one of these with long wires to somewhere visible - even inside the side panel would give readings you could check occasionally.
Ian
« Reply #20 on: July 05, 2020, 08:45:09 PM »
Nice one Ian. 15v seems high! I actually have a small round double usb socket with voltage display I had purchased to fit to the Pan I possibly could do a temporary fit to the 550. Turned out to be nice day later on, didn’t expect to be out on the bike today but managed a run around. Cheers!
1978 Honda CB550K3.
« Reply #21 on: July 06, 2020, 09:13:11 PM »
Temporary set up to check charging circuit.
1978 Honda CB550K3.
« Reply #22 on: July 07, 2020, 09:46:18 PM »
That is very neat. I watched some of this guys engineering videos, he is a bit of a genius. I don’t think I’m even worthy of owning a hacksaw never mind using one after watching Allen in action.
1978 Honda CB550K3.
« Reply #23 on: July 07, 2020, 10:50:04 PM »
It was Amazon. Flip up the cover and it’s a double usb socket. Bought to fit on my Pan. I have an unmolested low mileage model so was reluctant to cut into the plastic. Might make a bracket or something. Really just purchased more for the usb sockets than the volt meter, but makes sense to have both.
1978 Honda CB550K3.
Offline nairb
« Reply #24 on: July 08, 2020, 12:00:39 AM »
Those usb ports are great for charging the mobile phone.  I keep a portable one in my motorcycle jacket so I can connect it to any of my bikes.  Even charge on the go.  Make you wonder how we manged years ago.
« Reply #25 on: July 08, 2020, 10:26:47 AM »
Very handy! Do you just have clips on it to clip to battery terminals?
1978 Honda CB550K3.
Offline nairb
« Reply #26 on: July 08, 2020, 06:39:36 PM »
Just use the croc clips to the battery.  I'm sure a more sophisticated way could be done but it works for all the bikes I have.  Its the purple thing in the pic.  I think it came in other colours too.  It does work!.  I have charged the phone up several time over the years. Just get an data cable that suits your phone.
It saves having to charge the phone before you set off.....
« Reply #27 on: July 12, 2020, 07:06:21 AM »
Thanks guys for input and help! Bike is charging as it should so moving into phase 2 and going to spend another £4.
Flag connectors heat sinc and cable ties of the appropriate colour Steve. 😂😂
1978 Honda CB550K3.
« Reply #28 on: July 12, 2020, 08:45:19 PM »
Nice run out tonight 38 miles. Interesting monitoring voltage at battery during run. Had broad range from 12.4 to 15volts, I guess that’s the regulator acting on demand, mostly it sat at 14.4volts. Not sure if that would be normal.
. [ Guests cannot view attachments ]
1978 Honda CB550K3.
« Reply #29 on: July 13, 2020, 11:14:59 AM »
14,4 is perfect.
