Author Topic: Thread repairs  (Read 2611 times)
Offline Andy1976
  • '76 Honda CB750F1
Thread repairs
« on: July 19, 2009, 12:48:32 PM »
Hi all,
I've stripped 2 of the threads on my engine so as a result the rocker cover will not tighten down causing an oil leak.
Is using heli coils the correct way to go, and is it something I can do myself or do I need a motor engineer to do it?
Any advice is appreciated, as thread repairs is something I've never done.
Andy
Offline mick
Re: Thread repairs
« Reply #1 on: July 20, 2009, 10:33:08 AM »
Hi Andy i think you can diy and you can buy a kit but not sure where from hope fully someone else with better experience will chime in shortly  ;) cheers Mick.
Offline Seamus
Re: Thread repairs
« Reply #2 on: July 20, 2009, 12:47:48 PM »
Heli coil kits are easy to use. I have re threaded some for the same purpose as you.
Careful drilling of the hole and then tap for the insert (in the kit). Fit coil with the tool supplied and break off the tang. It is actually that simple. See http://www.fjr1300.info/howto/helicoil.html  for more detail.
There are different flavours of helicoil kit (recoil for example) Avoid the really cheap ones as they may not be so good.
Any good tool shop will sell you a kit. The kits come normally with everything for one size (eg M6).
A quick google will get you suppliers (example https://www.portlandtools.co.uk/Hand_tools/Thread_repair/ )
Good luck
Seamus
Re: Thread repairs
« Reply #3 on: July 21, 2009, 05:51:09 AM »
If its just the outer cover screw threads (rocker, points,clutch,etc) Helicoil is OK just need care and patience, if its a more stressed thread, like the cam bearing bolts/studs you need a "Keensert"
Offline Seamus
Re: Thread repairs
« Reply #4 on: July 21, 2009, 04:15:23 PM »
Re: Thread repairs
« Reply #5 on: July 21, 2009, 05:37:07 PM »
Used Keenserts for years, they are way stronger than helicoils and easier to fit BUT do need plenty of surrounding metal as for 6mm stud/bolt you are tapping out to 10mm.
You need to be carefull wherever you fit inserts that if the hole is a "through" hole and the inside has liquid oil you can get an oil leak down the threads so the insert needs to have the outer threads sealed and prferably a stud inserted again with thread sealer
Offline Andy1976
  • '76 Honda CB750F1
Re: Thread repairs
« Reply #6 on: July 22, 2009, 08:44:41 AM »
Thanks for the replies, I'm gonna have a go myself, so I've ordered the m6 helicoil kit from a local tool shop.
Andy
Re: Thread repairs
« Reply #7 on: July 22, 2009, 05:25:07 PM »
Just a thought, how bad are your threads, I cross threaded one of my rocker cover bolts changing them to Allen screws when the bike was new (1976 CB750F1), I got away with using a tap to re cut the threads and it's still OK now.
Den
Offline Andy1976
  • '76 Honda CB750F1
Re: Thread repairs
« Reply #8 on: July 22, 2009, 07:42:34 PM »
Hi Den, the threads are well mashed, I don't think re tapping will do it.
Andy
Offline hector2800
Re: Thread repairs
« Reply #9 on: July 22, 2009, 07:54:59 PM »
don't try and tap the thread all at once turn the tap back a full turn every so often or it can jam and snap and then you're in to a completely different ball game. You may know this already but I thought I ought to mention it.
Go on you know you want to
