Author Topic: Passing/Horn Switch and Trip Meter Knob  (Read 706 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« on: July 08, 2020, 12:41:47 PM »
Anyone know where I can source suitable knobs for the LHS horn/passing switch
and the odometer knob on the Speedo?
I know this one looks fine, but I need to take it off and I also know that this can be challenging.
I’ve checked on EBay with no luck.
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
Re: Passing/Horn Switch and Trip Meter Knob
« Reply #1 on: July 08, 2020, 01:39:56 PM »
You are looking for tripple chrome plated rocking horse poo there mate
« Reply #2 on: July 08, 2020, 05:39:03 PM »
When I bought my K3 it was missing from my bike. Nearly 30 years later I sourced a replacement handlebar unit through the channels of the sohc forum. I decided to restore my bike and source anything that was needing replaced or missing. Sorry I must add it didn’t take me 30 years to find a button, it just happened to be a considerable time lapsed until I decided to do something with the bike. Good luck! (I was referring to the horn/pass switch button)
1978 Honda CB550K3.
Offline kent400
« Reply #3 on: July 08, 2020, 05:39:52 PM »
 If you want to replace the grommet ideally you need to take the gauge apart as the remains of the grommet will be glued to the inside of the body. You can remove the knob be cutting it with a thin Dremel rotary saw blade, spread it slightly and pull it off.
When you are done push the knob back on and run a bead of two part resin glue in the saw cut. The knob wasn't glued on originally
it's just pressed on the shaft which has splines.
Offline SeanFD
« Reply #4 on: July 13, 2020, 09:09:31 PM »
Hopefully I’ll find one before 2050! 😂
